Thread: The 97-03 W-body buyers guide / Common problems
Page 3 of 3 FirstFirst 123
Results 41 to 49 of 49
  1. #41 Re: The 97-03 W-body buyers guide / Common problems
    I had a 97 GTP and I would trade off my 01 in a heartbeat to have it back, it had tire a pressure monitor, no traction control, actual lights inside the doors, no stupid cat diagnostic. Only parts on a 97 Gtp that are 97 only is the pcm. The throttle body, mass airflow sensor, tranny cooler lines, lines are threaded instead of quick release, and the blower has a vac tree on it, all of which can be changed.
    Sent from A Galaxy Far Far Away........
  2. #42 Re: The 97-03 W-body buyers guide / Common problems
    Dec 2012
    Where 4T65E's were born
    Quote Originally Posted by Slick2500 View Post
    And the DIC. A 97 gtp is not a dealbreaker but I wouldn't get a GT. Plus here in michigan with rust the rockers would be nonexistent.
    Sold.
  3. #43 Re: The 97-03 W-body buyers guide / Common problems
    Oh I forgot the DIC. Yeah only 97 I would get is a gtp. And my 97 was from Phoenix so the underside of the car looked brand new still.
  4. #44 Re: The 97-03 W-body buyers guide / Common problems
    SE Level Member CadVetteStang's Avatar
    Jun 2014
    Little Rock, Arkansans
    Thank you.Very good information. Very good.
  5. #45 Re: The 97-03 W-body buyers guide / Common problems
    Donating Users EHB's Avatar
    Dec 2014
    Maryland
    great info for us newb's
  6. #46 Re: The 97-03 W-body buyers guide / Common problems
    Dec 2012
    There are still a lot more w body common problems. Such as
    LCA hockey puck bushings, known to go sometimes before 100k. In the salt belt I think the collar rusts apart causing it to fail prematurely
    Motor mounts are hydraulic and known to fail earlier than solid mounts. Usually around 120k.
    Start and stall condition. On n/a its often caused by a bad fpr. Pull the vacuum line and check for gas, anything present means it's bad. The throttle body gets dirty after 100k miles and needs a good cleaning. I've fixed a start and stall issue by just cleaning the tb and IAC valve many times.
    On the n/a, if coolant is low, but there is no coolant in the oil, or any underneath; likely the uim is cracked between the coolant and egr port.
    Sold.
  7. #47 Re: The 97-03 W-body buyers guide / Common problems
    Mar 2015
    mn
    what sensor are you referring to for the key problem ?
  8. #48 Re: The 97-03 W-body buyers guide / Common problems
    Pensacola, FL
    Great write up!
  9. #49 Re: The 97-03 W-body buyers guide / Common problems
    Mar 2018
    NY
    I would also add to inspect the pinch welds underneath the car. A lot shops out there don't use the correct jacking points when putting the car on a lift which will cause damage. They also tend to rot out and collapse over time if the car is from the salt belt.
  1. BuYERS WATCH OUT
    By TheOtherNick in forum Off Topic Discussion
    Last Post: 02-03-2011, 01:04 AM
  2. What would you do? Buyers in FS Sale
    By BlownBigBlock in forum The Rant Forum
    Last Post: 01-21-2010, 07:38 PM
  3. Common Problems??
    By jayrayllc in forum General Tech Discussion
    Last Post: 11-01-2009, 09:49 AM
  4. Common Problems?
    By deadmittens in forum General Tech Discussion
    Last Post: 09-28-2009, 12:31 PM
  5. Common Grand Prix problems?
    By TronCarter in forum General Tech Discussion
    Last Post: 03-04-2009, 04:38 PM
