I just installed my headers and now i cant find the hole that the dipstick plugs into. Can anyone help?
Maybe jack it up, have a buddy hold your dipstick while you guide it in the hole.
EDIT: Giggity.
i have found it easier to find the hole if you leave the stick in the tube, prob till the stick dips in the hole. then guide the tube in.
gives you more flex to your prob lol
use a light and look by the back of the ac compressor....right above the oil pan on the block.
Why did you pull the dipstick out? I didn't need to on my car when I did headers.
I had the same problem because its hard to see. Put your hand down there and feel around, you will find it. lol
Im also installing headers on my 05 GP I didnt even remove the dipstick , I just bended the plate a bit and out with the old and in with the new
I always pull it. The hole is easy to see from teh top with headers....once you know where to look. I guess it would be a good thing to look for when the exhaust is off. Then you'd knwo where to look for reinstallation.
