Thread: Cold Air Intake - '08 Grand Prix Base Model
Results 1 to 15 of 15
  1. #1 Cold Air Intake - '08 Grand Prix Base Model
    Dover, DE
    I've looked all over on the internet and it seems like I can't find a single intake kit for my GP. All I can find is the '04 and '05 model intakes. Also if anyone happens to know why my car would say Service Theft System on the display and then turn the guages off, I would greatly appreciate any kind of knowledge pertaining to that.
  2. #2 Re: Cold Air Intake - '08 Grand Prix Base Model
    you should take some time and make your own intake. not only will it be better than anything you buy, it will be significantly cheaper.
  3. #3 Re: Cold Air Intake - '08 Grand Prix Base Model
    Donating Users Durk Diggler's Avatar
    Pittsburgh
    There isn't any difference b/w an 04 and 08 NA intake.
    Go to the hardware store, get two 3" to 4" rubber pipe fittings, a curved 4"PVC pipe, and a conical filter of your choice.
    Durkz 04 Silver GT2
    DHP'd, Comp G'd, looking for more speed
    http://www.grandprixforums.net/zzps-new-website-2-53834.html#post678234
  4. #4 Re: Cold Air Intake - '08 Grand Prix Base Model
    The LED guy.... csssaint12's Avatar
    Nov 2009
    Duluth, Minnesota, United States
    I got just mine off of eBay from Chrome Intakes.
  5. #5 Re: Cold Air Intake - '08 Grand Prix Base Model
    GTP Level Member
    Nov 2011
    Kansas
    The ones from the 05 will fit the 08.... however, I just did this, $40 and done. However, I still want to remove that corrugated piece.
  6. #6 Re: Cold Air Intake - '08 Grand Prix Base Model
    Pennsylvania
    that corrugated piece is the piece where most of the restriction is, the bumpy corrugation causes turbulence and it backs up the air. Dirk knows whats up, that's what I did on my 08 and it works and sounds great. Costed me probably 30 bucks total, including the filter.
    Adapter on TB > pvc section > adapter on pvc section > MAF > Filter > Happy
    Also, while you're in there with your intake off, I took my TB off all together and took some tb cleaner to it, wiped it out really good, let it dry.. same with the MAF, except use MAF cleaner, nothing else, and do not touch the wires inside with anything, just spray it down and let it dry 100%.
    Sport Edition Kv5 18x8
  7. #7 Re: Cold Air Intake - '08 Grand Prix Base Model
    Dover, DE
    Much appreciated for the info with intake, when I get back from this deployment I will be able to make my own. Does anyone know about the theft system though? I heard that it might be the chip in the key possibly, cause it does have a slight bend and when it happens I turn the car off and unlock the door with the key and it works for a while, so should I go to the dealership when it happens so they can test the system?
  8. #8 Re: Cold Air Intake - '08 Grand Prix Base Model
    Durkz has K&N sticker...but no kayenenz
    LIESSSSS.
    But seriously, lol....Like everyone says...make your own.
    You'll be glad you did when the $50~ intake is on par or surpasses the $300 K&N junk.
  9. #9 Re: Cold Air Intake - '08 Grand Prix Base Model
    Sep 2016
    Columbus, Ohio USA
    You guys are the ****.... every time I need something you guys are always there
  10. #10 Re: Cold Air Intake - '08 Grand Prix Base Model
    Feb 2019
    US
    Quote Originally Posted by develand View Post
    What did you do about the front section of the air box blocking where your filter is sitting? I just got a CAI off eBay for my 08, and I can't figure out the best way to remove it without screwing up what I think is the ECM mounted at the bottom. I'm also getting a code for incorrect upstream airflow, what's the best way to rectify that? Thanks in advance.
    Sent from my LM-G710VM using Tapatalk
  11. #11 Re: Cold Air Intake - '08 Grand Prix Base Model
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by RaevynCarrion View Post
    You need to take the cross brace off and then take that part of the box out of there. If I remember correctly you need to pull up hard on it. Also, you need to get rid of that stock accordion hose. That is the most restrictive part of the system.
  12. #12 Re: Cold Air Intake - '08 Grand Prix Base Model
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Quote Originally Posted by JWild View Post
    The 04 and 05 fit but if you get one with a full box the 08 air conditioning lines will interfere with the fit. It will fit though.
  13. #13 Re: Cold Air Intake - '08 Grand Prix Base Model
    GTP Level Member
    Jun 2016
    Cleveland ohio
    As for the exam you secure it below the filter on the flat spot the OE box used to be
  14. #14 Re: Cold Air Intake - '08 Grand Prix Base Model
    GTP Level Member
    Jun 2016
    Cleveland ohio
    ECM*
  15. #15 Re: Cold Air Intake - '08 Grand Prix Base Model
    Feb 2019
    US
    Thanks for the replies, guys. I ended up cutting the box so I could retain the factory ECM mounts and put it back in. I'm goin to respect that accordion when I have more cash for, the air intake was a gift so I'm on limited options atm. Here's a rough picture of progress, I know I need to redo the paint on the bars.
  1. Installing Factory Monsoon Headunit w/ XM - in base model Grand Prix?
    By extreme in forum Audio, Security & Visual Electronics
    Last Post: 12-27-2011, 06:34 AM
  2. Supercharger for '07 grand prix base model 3.8 L26
    By tino153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-26-2011, 08:14 PM
  3. Cold Air Intake 2008 (Base 3.8)
    By lolwtf in forum General Tech Discussion
    Last Post: 04-10-2011, 04:10 PM
  4. Cold Air Intake on base grand prix???
    By rashan in forum General Tech Discussion
    Last Post: 09-29-2010, 01:25 PM
  5. 235/50-18 will these fitt base model 06 Grand Prix?
    By Shake_Zula in forum Tires & Wheels
    Last Post: 02-17-2009, 02:07 PM
