Thread: washer fluid not working
Results 1 to 6 of 6
  1. #1 washer fluid not working
    Jan 2012
    wentzville
    hey guys im a new owner of a 2000 gtp, now im having problems with the washer fluid not spraying, when i hit the switch i cant hear the motor buzzing at all, so it leads me to beleive its an electrical problem, im trying to find the fuse for it but cannot seem to find the one that goes to the washer motor, any ideas? the only fuses i can find are the ones in the engine bay by the battery, are there more somewhere else? thanks in advance
  2. #2 Re: washer fluid not working
    the motor itself is probably bad. I have one in my garage if your interested in buying one.
  3. #3 Re: washer fluid not working
    Jan 2012
    wentzville
    well the new pump is only $16, so ill probably just buy a new one if need be, but do you know where the fuse for it is? just so i can check that first!!
  4. #4 Re: washer fluid not working
    I'm not sure but if you have a tester you can just pull the plug at the pump and check if you have 12V there.
  5. #5 Re: washer fluid not working
    Waukesha, WI
    had the same problem, replace the motor every 6 months, acdelco motors everytime, i cleaned the transfer tube and squirters and havent had a problem since.
    RayRay
    92 Turbo miata
    71 bagged lemans wagon
    02 lexus is300
  6. #6 Re: washer fluid not working
    GTP Level Member buickman104's Avatar
    NYC
    Yup. I got a new pump from rock auto for about $14. Replaced it while I was doing an oil change since it's right there anyway. Has been good for over a year with no problems. Knock on wood.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. washer fluid pump
    By thewaitinggame in forum General Tech Discussion
    Last Post: 04-26-2011, 08:17 PM
  2. Washer Fluid Low Light always on
    By tdm571 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-28-2010, 09:12 PM
  3. Windshield washer fluid
    By flyboyray1 in forum General Tech Discussion
    Last Post: 03-18-2010, 10:07 PM
  4. Low Washer Fluid
    By ericrluoma in forum General Tech Discussion
    Last Post: 09-17-2009, 11:11 PM
  5. Washer Fluid Injection
    By 98GT3800 in forum General Tech Discussion
    Last Post: 10-21-2008, 11:51 AM
