Thread: GTP Problems on my 97
Results 1 to 9 of 9
  1. #1 GTP Problems on my 97
    Dec 2011
    Wayne ne
    My car runs fine butt when i check the oil or take off the oil cap it seems to be pulling in air and makes my motor squeel a bit if i dont keep the dipp stick out to stop the air from sucking into the motor, I have replace the pcv dint help any idea Thanks
  2. #2 Re: GTP Problems on my 97
    Jun 2011
    Detroit, MI
    Well something might be blocking the pcv or something. So you are saying your engine runs better with the oil cap off? Then you should get a valve cover breather.
    iLoveSpade
  3. #3 Re: GTP Problems on my 97
    GT Level Member grandamle91's Avatar
    Jun 2011
    Watertown, SD
    Mine was doing the same thing and it turned out to be the pcv o ring
    2000 GP GT 3.8 NA Stock Engine - Cat, EGR Deleted - K&N Cone - Pulstar Pulse Plug ad1h10 -6k HIDS- LEDS
  4. #4 Re: GTP Problems on my 97
    Moved thread.
    Please post in the correct section for your topic.
  5. #5 Re: GTP Problems on my 97
    Dec 2011
    Wayne ne
    Sorry about posting in the wrong area still learning the site. I replaced the pcv and o ring seems to be fine Any one know where it could possibly be pluged at in the system? Thanks for the Help im Stumped
  6. #6 Re: GTP Problems on my 97
    Dec 2011
    Wayne ne
    It runs the same for the most part makes a bit of a noise of sorts in the motor when the preasure builds up i open the cap or pull the dipstick out and it suck air in and then stops Crazy!
  7. #7 Re: GTP Problems on my 97
    Omaha, NE
    Change the PCV valve itself. It's $2-3
  8. #8 Re: GTP Problems on my 97
    Dec 2011
    Wayne ne
    Did that know change used the old O ring dnt look bad maybe i should try and change that to ?
  9. #9 Re: GTP Problems on my 97
    i think there are 2 o rings for the PCV
  1. abs problems?
    By astros2900 in forum Brakes/Suspension/Chassis
    Last Post: 03-20-2011, 09:36 AM
  2. Rpm problems...
    By Ferni in forum General Tech Discussion
    Last Post: 03-01-2011, 04:11 PM
  3. HID problems AGAIN
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 07-26-2010, 07:12 AM
  4. 07 gxp with nav mp3 problems
    By pjs29 in forum General Tech Discussion
    Last Post: 08-22-2009, 01:11 PM
