Thread: gas mileage
Page 6 of 38 FirstFirst ... 4567816 ... LastLast
Results 101 to 120 of 755
  1. #101 Re: gas mileage
    GTP Level Member AjL227's Avatar
    IL
    I drive this car to work 5 days a week, three miles away.
    With no traffic, I can get home from work in 12 minutes.
    However, I'm often forced to sit behind one lane backup every morning besides Saturday.
    Side streets get me to work quickly after i can cross the train tracks and ditch the one lane road, taking around 18 minutes.
    I'm seeing 200-220 miles from ~15 gallons of winter blend 93...
    thus ~13-15 city mpg.
    I need a daily driver for all this idling.
    '04 CompG "WS6"
    '00 2.5RS "GM6"
  2. #102 Re: gas mileage
    SE Level Member Mater's Avatar
    Feb 2010
    my house
    the GTP is getting 24mpg average int he summer it was around 26-27 average
    the merc gets 15mpg and about a set of tires every 3 months lol
    But why make it an SE?
    99 Grand Prix SE coupe:
    junk yard trans junk yard engine and junk yard turbo
    03 Silverado 2500HD ECSB: 6.0 4x4 01 Aurora:​ 4.0L vin number 2
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    900 mile road trip last week, averaging 70-80mph.....between 26-27mpg
    01 GT 55,000 miles
    Sent from my DROID RAZR using Tapatalk
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  4. #104 Re: gas mileage
    Jun 2010
    winston-salem
    computer says i average 13.5 miles city, and about 18 highway. I dont doubt it either, I have quite a lead foot. I feel like it should be better though?!
  5. #105 Re: gas mileage
    GT Level Member Remnant King's Avatar
    Nov 2010
    Michigan
    lol that's right where it should be I would say.
    You can't expect to be a lead foot and get better gas mileage, if you hope to improve your mileage, your rpm's have to be under 3k.
    I drive somewhat normally and still manage to pull off 16-18 mpg in the city.
    2000 Midnight Blue Grand Prix GTP Coupe
  6. #106 Re: gas mileage
    Feb 2010
    my house
    the reson my milage is i live out int he middle of the country and the closes city is 15 minutes or 30 minutes depending on witch oen i need to go to
  7. #107 Re: gas mileage
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    since the tune and downpipe i been checking my intown driving cause thats all this car gets, and getting 19-20 mpg intown with normal/reasonable driving, sure it will get better in the spring but still happy with the results.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  8. #108 Re: gas mileage
    Ohio
    I was getting 18.8 with medium foot 21.3 with light foot in summer and fall and pulling around 30 freeway but now with the cold and winter gas I'm stuck around 15.3-16.7 city and 24 @70-75
  9. #109 Re: gas mileage
    SE Level Member silentkreeper95's Avatar
    Jan 2012
    Las Vegas,Nv
    Computer says i'm getting 17.3mpg city and thats with 2 drivers and driving styles.
  10. #110 Re: gas mileage
    Topeka, KS
    I've probably wrote this before but this seems to be helping me alot. I drive 30min to an from work. 90% hwy. I was getting some pretty crappy mileage. I've recently tried not to beat on it like a whore and kept my rpm's no higher than 2200rpm at cruise. If you encounter a slight grade so what keep your foot there. You will slow down some sure... but you'll speed back up when you get to a downhill grade or level grade. This has taken my crappy mileage of 20-21mpg combined to almost 27mpg. Alot has to do with your tune as well granted but 80% of it is your right foot and the distance you are driving.
    Also try to keep your tires properly inflated.
    Just a little tid bit I thought I would share again.
  11. #111 Re: gas mileage
    St Thomas Ontario
    pulled 33 mpg going 50 mph cruise on a very straight road for 40 minutes, my old man was amazed as much as i was lols
  12. #112 Re: gas mileage
    Jan 2012
    N/A
    Im getting like 200 miles per tank 2004 gtp
  13. #113 Re: gas mileage
    GT Level Member EJRJR91's Avatar
    Nanuet, NY
    i re-did mine, i'm getting about 19-20 but thats a mix of thruway and city driving
    2002 Pontiac Grand Prix SE --> Audio, Lighting, Exterior
  14. #114 Re: gas mileage
    GTX Level Member Steel Armadillo's Avatar
    Orlando, Florida, United States
    About 25-26 around town beating on ricers, playing road warrior. I once saw 28.1. From Orlando, to Miami, to Vero Beach I got 27.6 running 80-90 except inside Vero And Miami city limits.
    The evil LG8 still refuses to die.
  15. #115 Re: gas mileage
    Jan 2012
    Philadelphia
    i get 17.2 when im driving normal and i drive like 20 miles a day usually and my gas gauge or range dont even work i ran out of gas a couple time before too
  16. #116 Re: gas mileage
    Mar 2012
    Minnesota
    Not sure how much on a full tank yet but just filled up and with using an eighth tank of gas I've pulled 70.3 miles. With 50/50 city/highway. Rather surprised with the factory fuel filter, kinda a dirty air filter, and a need of new plugs and wires. Wondering what brands you guys have found best use in filters and plugs, I was thinking ac delco for the plugs, wires, and fuel filter then either wix for a temp air filter or K&N for a more permanent replacement, any input? Thanks
    Delco for plugs, wires, fuel and trans filter.
    Note delco trans is an SPX Filtran filter. Unsure of origin of other delco products minus or filter. Those are champion labs econo design and should be avoided if you fear fram filters.
    I'm enjoying my amsoil air filter more than either of my k&n's.
  18. #118 Re: gas mileage
    Mar 2012
    Minnesota
    Okay, thanks, on the car i owned before my gp, a 2000 jetta tdi, i had a K&N cold air intake i customized to fit the MAF into and on the forums for that everyone said that K&N is the MAF killer. I was just wondering if the sentiment here is similiar.
    Eh... Only if you over oil.
    However they don't seem to be the best at filtration which is key to engine life.
  20. #120 Re: gas mileage
    Nanuet, NY
    anybody notice a change after putting in a cai? i havent put one in, just curious
  1. Gas mileage
    By Zyrebel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-17-2010, 01:02 PM
  2. 04+ S/C gas mileage
    By carl06GT in forum 04+ Specifics
    Last Post: 08-30-2010, 08:17 AM
  3. Why am I getting bad Gas Mileage?
    By JDCMoney in forum General Tech Discussion
    Last Post: 06-10-2010, 01:34 PM
  4. What can I do to get better gas mileage?
    By isucyclones3 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-19-2009, 11:58 PM
  5. Gas Mileage
    By TCO in forum Off Topic Discussion
    Last Post: 05-07-2008, 11:01 AM
