Thread: Power Steering question on 1997 GTP
Results 1 to 7 of 7
  1. #1 Power Steering question on 1997 GTP
    Nov 2017
    Ravenna Mi
    Coming home from work and my power steering starts whining....hmmmm must be low on fluid. Get home and put some power steering fluid in and start her up and trun the steering wheel back and forth a couple times and she keeps whining...not as bad but still whining. Shut her off and look underneath the car ...oh looky....a big pool of power steering fluid. GRRRR
    Had to go to Autozone to pick up a part for another car I'm working on and ask them what lines need to be replaced and they ask me if it's brake assisted..or something like that??? ?? So apparently on some of these car the power steering is tied into the brake system?!? How do I know iof my is one those? Sorry I'm being a little vague but this is all new tow me, tieing the power steering into the brake system....I'm a little confused.
    Thanks in advance for any help
    And to the Forum moderators, if this post is not in the right place, I apologize
  2. #2 Re: Power Steering question on 1997 GTP
    St. Louis
    No, the steering is not a hydro-boost setup. It's either just plain gears or maybe Magna-Steer (variable assist). If you have a single wire electrical plug coming off the rack where the steering shaft boot is on the drivers side then it's Magna-Steer.
  3. #3 Re: Power Steering question on 1997 GTP
    Nov 2017
    Ravenna Mi
    'Thanks for the clarification. Now I put my other projects on hold and work on this piggy.....yaayyy.... lol
  4. #4 Re: Power Steering question on 1997 GTP
    theres a good chance its the return line thats just clamped on the pump leaking, they like to split a inch off the pump. you can just cut the line at the crack and put it back on the pump. line replacement is no fun. you need to lower the sub frame to get a good clear shot at the line bolts on the rack. not all that bad really, car on stands, jack under the frame, remove the two rear sub frame bolts and lower the jack 3-4 inches.
    then the pump, should it need to be replaced is a super treat, theres only two bolts holding it to the engine, but your getting to them via the hole in the pump pulley, so your semi blind re installing it. ive fought with them for a 1/2 hr, and other times got super lucky and they just went right in place and bolted in.
  5. #5 Re: Power Steering question on 1997 GTP
    Nov 2017
    Ravenna Mi
    awlrighty then...It is sounding like this will be one of those jobs where colorful language is very present and plentiful... lol
    I will first check the return line and see if that is the issue...
    or maybe I'll push it out in the back of the property with a stick of dynamite tossed into the gas tank....lol
    No, not really. I'd have a hard time explaining to local Law Enforcement how my car exploded....lolol
  6. #6 Re: Power Steering question on 1997 GTP
    this was a rack swap, so you dont want to drop the frame this much or you'll rip the steering shaft apart, or worse. them two lines are the ones you would change, Shared album - Scott R - Google Photos
  7. #7 Re: Power Steering question on 1997 GTP
    Nov 2017
    Ravenna Mi
    Thanks Scottydoggs....Ill be tearing into this POS today. Sorry if I seem a little whiney....it's just that I have been working on various vehichles here for the last 4 weeks. I have a 1989 Chrysler TC by Maserati (a two seater with removalble hard top and also a convertible top) and have had to replace both front calipers, then both front rubber brake lines and then brake pads. Then I had to replace the new passenger caliper again because to pressure piston had a chip taken out of it....grrrrrrr...
    So like I said, sorry for being a whiney a$$...lol
  1. Power Steering Question
    By Hurricane87 in forum General Grand Prix Discussion
    Last Post: 12-15-2021, 10:39 AM
  2. Power Steering Pump Question
    By Hair in forum General Tech Discussion
    Last Post: 12-30-2017, 02:26 AM
  3. Power steering question
    By traildog in forum General Tech Discussion
    Last Post: 01-17-2014, 09:37 AM
  4. Power steering question
    By Whitehispanic in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-05-2011, 03:00 PM
  5. power steering question please help
    By mcsddd in forum General Tech Discussion
    Last Post: 12-05-2010, 10:47 PM
