Thread: It goes on and on with my car
Results 1 to 9 of 9
  1. #1 It goes on and on with my car
    Jun 2018
    Schweiz
    Hi all
    I posted about the mess with the codes on my 2000 Pontiac Grand Prix GTP before here in the forum.
    Last code was P1133
    But now I have:
    P1133
    P1361
    P1362
    And now I have a check engine light.
    It goes on and on theres no end or anything I think all on this car is a mess.
    These codes are for the ignition module and the crankshaft position sensor I think.
    ​What can I do against this?
  2. #2 Re: It goes on and on with my car
    St. Louis
  3. #3 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    Yes and no it was there after the check engine light came on.
  4. #4 Re: It goes on and on with my car
    St. Louis
    FYI, my post is a link to some info if you didn't click on it.
  5. #5 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    Yes saw it...thanks
    Thats why the indicator light is off now:
    • The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  6. #6 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    And now next thing:
    Sometimes car has misfires with ignition and after this the Computer goes wild.
    All is blinking
    I think this is due the codes I have the p1361 and p1362 codes
    ​I don't know but the car is only scrap and I can't drive it anymore
    Indicator light is on again
    If I have a short in the wires somewhere then good night can't find out by myself.
    So many parts are new: The O2 sensor by the engine, the igition modules the ICM don't know what to do now
  7. #7 Re: It goes on and on with my car
    The Boss Iceman6669's Avatar
    Jun 2011
    I would check the harness for the cam and crank position sensors. If the harness gets messed up it can cause those codes to pop up.
    2011 F-150 Yote powered
  8. #8 Re: It goes on and on with my car
    Jun 2018
    Schweiz
    Where is the harness for the cam?
    For the crankshaft sensor its ok
  9. #9 Re: It goes on and on with my car
    St. Louis
    It comes off of the harness for the ICM if I recall. It runs down under the coils/ICM and into the front of the engine. Cam is up top and then the crank sensor lives behind the crank pulley/balancer. It can get rubbed by the drive belt if not secured properly, seen that one before.
