Thread: Got codes
Results 1 to 11 of 11
  1. #1 Got codes
    Jun 2018
    Schweiz
    Hi all
    Got some codes on my car - 2000 Pontiac grand prix GTP
    Codes:
    P0133
    P1573
    I drove the car and then it had no ignition for a few seconds and then all be normal.
    After this I've got the codes and the computer goes mad.
    The TCS light was on everytime the computer shows only 0.00 in the fuel consumption.
    So then I thought this must be the igition coils.Because I had before some problems with them.
    I changed all on the car and the ignition coils also back to stock the car ran great no problems no code.
    I changed them back and deleted the codes and now we will see if all is ok.
    The coils I had where the ZZP coils (4 years old).
    The coils I have now are these:
    For 2000-2003 Pontiac Grand Prix Ignition Coil and Spark Plug Wire Set 47811DQDR | eBay
    Hope these are original coils because these are the best
  2. #2 Re: Got codes
    Canada
    Neither of these codes are related to ignition coils. P1573 is lost comm to the EBTCM and P0133 is slow response from an O2 sensor. You may have two issues or a bad PCM. As for the eBay coils, they are not stock and stock are the best. Even stock coils from a junkyard will be better than any other brand.
    '01 Grand Prix GTP Special Edition
    Trying to stay pretty close to stock now. Just a few bolt-ons for fun.
    Trying to keep it alive, pretty, and fun.
  3. #3 Re: Got codes
    Jun 2018
    Schweiz
    Thats interesting. I changed the O2 sensor already.
    The EBTCM I don't know how to fix it or where to get a new one.
    But if I have no failure codes now after changing the ignition coils then all will be good.
    Bad PCM? Its a PCM from ZZP I have. After 4 years gone bad? ok
    nothing surprises me anymore.
    ​Had the same with the ignition coils from ZZP also.
    The second problem is I have awful gas consumption......it goes higher and higher everytime. Whats that?
  4. #4 Re: Got codes
    Jun 2018
    Schweiz
  5. #5 Re: Got codes
    Canada
    That is a repair service for the EBTCM. These modules are known to fail. New ones are far too expensive and it is not possible to be sure of anything from a junkyard. Probably the most reputable repair service is the one below. I just had a repair completed a few months ago.
    REPAIR KIT for 1997 - 2003 Pontiac Grand Prix ABS Control Module We Install | eBay
    Quote Originally Posted by kappa67 View Post
  6. #6 Re: Got codes
    Jun 2018
    Schweiz
    Thanks..
    And here you can order the whole kit...
    CHEAP ABS Module Repair for Audi
  7. #7 Re: Got codes
    Canada
    @Kappa67, that is a great deal.
  8. #8 Re: Got codes
    Jun 2018
    Schweiz
    Now I have only one question:
    The car has such high fuel consumption.
    Why? Before it was down on 10l/100km
    And now at 16,5l/100km.
    ​Whats that?
    And I drove the car today an had no codes...this all with the new ignition coils
    Think the old ones where a problem.
  9. #9 Re: Got codes
    Canada
    You might want to check your plugs to see if you can determine if one is not firing well. I know you will not want to hear it but, having gone through this several times myself, grab a set of original coils. Even ones from a junkyard. I have had two sets of MSD coils in my car and both caused acceleration issues intermittently. I swapped one coil at a time with stock coils and ended up with all stock coils both times. Both times, I tried every combination and permutation of stock+MSD coils trying to isolate the bad coilpack(s). The first time, if any of the MSD coilpacks were installed, I had problems. The second time, after many coil swaps, they just started working without issue. It is inexplicable to me. There was a problem, then suddenly there was not. I slowly backed away from the car, gave it an appreciative nod, and closed the hood. They have been there for the last couple of years.
    The upshot of all this, while struggling through the above, all of my experience and research demonstrates that the stock coils just work. There is no performance gain from any aftermarket coils so the only reason to do it is aesthetics which is why I persisted. In the back of my mind, I know that there is a good chance that I will have to abandon the pretty red ones at any time.
  10. #10 Re: Got codes
    Jun 2018
    Schweiz
    Yes thanks Jeepers
    I think this would be the solution the original coils. If my coils are broken I will order the original from rockauto. Can paint em red and looks good.
    The plugs should be ok...because now the car runs straight without problems.
    For me :
    Buy original coils they are the best!
    Will follow this advice.
  11. #11 Re: Got codes
    Jun 2018
    Schweiz
    Got no codes until today...one was there:
    P1133
    must take a look what this is
  1. codes
    By Stone in forum General Grand Prix Discussion
    Last Post: 09-04-2017, 09:20 AM
  2. Need help with codes
    By skippy in forum Introductions/Noob Questions
    Last Post: 04-13-2013, 12:34 PM
  3. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  4. i got some codes?
    By gpse2000 in forum General Tech Discussion
    Last Post: 09-28-2011, 09:24 PM
  5. Codes
    By 3uzzkill in forum 04+ Specifics
    Last Post: 08-25-2011, 10:04 PM
