Thread: does this sound like a bad thermostat?
Results 1 to 8 of 8
  1. #1 does this sound like a bad thermostat?
    Jun 2024
    Birmingham Al.
    '98 Gran Prix GTP 3800-SC..127,000miles..when cranking cold it takes a while(several miles) to get up to 185/190 on the instrument guage but levels off there..after driving 20-25 miles and getting into several stoplights on a 95 degree day with the a/c on..guage will creep up 2-3 notches past 185 on guage(guessing around 195/200) then will go back down to 185/190 after a few minutes of unrestricted driving..Thanks-David
  2. #2 Re: does this sound like a bad thermostat?
    St. Louis
    That sounds like normal temps. Believe the stock thermostat is a 195*.
  3. #3 Re: does this sound like a bad thermostat?
    Jun 2024
    Birmingham Al.
    Quote Originally Posted by FordMan77 View Post
    thanks man..but shouldnt the temp gauge stay constant in a perfect scenario?
  4. #4 Re: does this sound like a bad thermostat?
    St. Louis
    No, mine and my brothers GP does the same thing. Sitting in traffic I always notice the gauge creep a bit until I get moving. Even with the A/C on (which automatically calls both fans ON) the temp is going to rise. I've got around 400K on my engine currently and it hasn't cooked itself yet. My 95 Bonneville with the same series II 3800 is at 312K and acts exactly the same.
    If the coolant is old then I'd just flush the system and refill with standard green coolant and call it a day.
  5. #5 Re: does this sound like a bad thermostat?
    Jun 2024
    Birmingham Al.
    thanks for the info..ditch the orange dex-cool and go with green?
  6. #6 Re: does this sound like a bad thermostat?
    St. Louis
    Yep. Flush the entire system until it's clear (don't forget to clean out the overflow bottle). Once you get it clean, I usually just drain the radiator and refill that and the coolant bottle with green. Should be about the perfect mix of water/coolant. And do NOT buy the pre-mixed stuff or your water/coolant ratio will be off.
    There are instruction on here on how to bleed the cooling system as well. Yes, there is a proceedure, lol..
  7. #7 Re: does this sound like a bad thermostat?
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by Guff55 View Post
    flush the hell out of it. I flushed water through one of the heater core hoses, then pulled tstat housing, flushed into engine, in rad hose there into rad, through filler neck, put tstat housing on without tstat, filled with water, ran for a while, flushed, refilled, ran, then final flush. my water pressure at hose sucks so it wasn't great but It cleared a lot of crap out.
    08 grand prix NA3800
  8. #8 Re: does this sound like a bad thermostat?
    Aug 2021
    Texas
    my 2003 w 79,000 acts the same way.........
  1. Grinding sound when making sharp left and awful creak sound when going over bumps
    By rescuetoaster in forum Brakes/Suspension/Chassis
    Last Post: 03-04-2012, 10:06 PM
  2. bad thermostat?
    By jwhite85 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-20-2011, 12:22 PM
  3. Best thermostat
    By ATLgrandprix78 in forum Introductions/Noob Questions
    Last Post: 08-12-2010, 08:55 AM
  4. Thermostat!????
    By fratzke7 in forum General Tech Discussion
    Last Post: 03-16-2009, 11:35 AM
  5. Thermostat
    By keenan00gtp in forum General Tech Discussion
    Last Post: 10-20-2008, 05:46 PM
