Thread: abs, traction, brake light
Results 1 to 2 of 2
  1. #1 abs, traction, brake light
    Sep 2023
    Mapleton, nd
    Recently my abs, traction, and brake lights all came on. At the same time, my car would shut off all power if the wheels spun too much. I went ahead and read the codes and did have a wheel speed sensor code which I went ahead and fixed right away. The codes remained after were c0896, c0898, and c0550. I went and read the system and found the abs module read 0 volts, tested the power and ground circuits and found everything read fine, I went ahead and took out the module and sent it here 97-07 PONTIAC GRAND PRIX ABS REPAIR - Module Repair Pro INC . I pretty much just stated what was going on with it and got it back in a little less than 2 weeks and now it's fine and no abs code or brake light 👍 if anyone is having the same issues I had, I hope this somewhat helps and it costed around $200 and a nearby shop wanted 1100 to have them fix it. There's also a couple videos on YouTube on how to remove it if you don't know how for some reason, this also follows for any model grand prix I'm pretty sure. I have the 06 gxp
  2. #2 Re: abs, traction, brake light
    The Boss Iceman6669's Avatar
    Jun 2011
    2011 F-150 Yote powered
  1. Traction and brake light still on after replacing wheel bearing
    By Kadeas in forum Brakes/Suspension/Chassis
    Last Post: 07-28-2022, 02:54 AM
  2. Replies: 14
    Last Post: 07-15-2017, 08:01 PM
  3. Replies: 2
    Last Post: 07-20-2013, 08:25 AM
  4. ABS/Traction/Brake lights on
    By jkazam1 in forum Brakes/Suspension/Chassis
    Last Post: 07-30-2012, 06:46 PM
  5. Traction control light and abs light on
    By Torri040 in forum Brakes/Suspension/Chassis
    Last Post: 09-02-2011, 04:03 PM
