Thread: 2004 pontiac grand prix GTP electrical gremlin? Who knows, hopefully someone
Results 1 to 3 of 3
  1. #1 2004 pontiac grand prix GTP electrical gremlin? Who knows, hopefully someone
    Oct 2023
    Ohio
    Mods: Walbro 255, HPtuners tune, cold air intake, straight piped, 3.4in pulley
    Now to get into the issue. so Friday the car died ideling in some heavy traffic and wouldn't restart just crank, so I being the young strong boy I am pushed it into a parking lot and let it sit for about 10 min while waiting for a ride, tried to start it before I left and it ran for about 30 seconds then died and just cranked after.. My dad came about 45 min later had it running for 20 minutes in the parking lot, and brought it over to me at work (caddy corner to the parking lot) and I got in it to take him back to his car and it died in my works parking lot and wouldn't start again, again cranking and not starting. Got it running about 20 min later, got it to my bay at work and it died yet again. We swapped out the ICM, still did the same thing. Yesterday we swapped the crank position sensor because I've heard that could've been my issue, still didn't resolve it. Key on engine off I get 50psi to the rail, running it gets 67 up until it shuts off (because it shut off it doesn't go under 67 at all). I even made sure i heard the pump running up until it died, and it does. We also checked spark when it wouldn't run just crank, and it HAS SPARK but won't run. Nothing on scan tool data looks crazy, cam & crank sensors look very close (within 5-15 rpm which I assume is normal), MAF, MAP, etc readings all look exactly the same as any other time, day, etc. Someone please give me a lead!
    We've also cleaned throttle body if that matters at all.
  2. #2 Re: 2004 pontiac grand prix GTP electrical gremlin? Who knows, hopefully someone
    St. Louis
    Do you have a second key to the car you can try and use? Wondering if the current one is getting worn and maybe tripping the theftlock.
  3. #3 Re: 2004 pontiac grand prix GTP electrical gremlin? Who knows, hopefully someone
    Nov 2022
    Findlay
    I have had to replace the battery to body ground on the fiances 04 for similar issue, randomly dying then not restarting for a while. The threads for the bolt were all rusty, put in a new cable from terminal to the underside of the crossmember that goes over the battery, scraped the paint off under it, problem solved
  1. 2004 Pontiac Grand Prix
    By missmarymisc in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-08-2017, 07:58 PM
  2. Headlines light electrical issue 2007 Pontiac grand prix
    By Pilzenkopf in forum Visual/Body Modifications
    Last Post: 03-31-2017, 03:31 PM
  3. Electrical gremlin
    By dgjks6 in forum General Tech Discussion
    Last Post: 10-14-2016, 08:07 PM
  4. 2006 Grand Prix Transmittion Gremlin
    By rev21jon in forum General Grand Prix Discussion
    Last Post: 12-24-2013, 11:13 PM
  5. 2004 Grand Prix Gt electrical issues
    By hydrashock in forum General Tech Discussion
    Last Post: 03-18-2013, 02:06 PM
