Thread: Mix of Weird Symptoms
Results 1 to 9 of 9
  1. #1 Mix of Weird Symptoms
    Feb 2022
    USA
    2005 GT.
    120,000 miles.
    Twice in the last couple of weeks the car just died
    while driving it. Pulled over, restarted it, kept going.
    Today when my wife got home, she shut the car
    down and said it "vibrated" when she turned it off.
    She went back out later and it started but
    then immediately died and wouldn't restart.
    Then I went out and tried it.
    As soon as I cranked it, it fired, but the starter
    stayed engaged for a couple of seconds after I
    let off on the key, then the engine immediately died.
    Meanwhile every gauge on the cluster was going haywire.
    Tried a few more times, exact same thing happened every time.
    Any ideas?
    Thanks in advance.
  2. #2 Re: Mix of Weird Symptoms
    Apr 2014
    commerce twp,mi
    i would start with reading codes. there are a few things that could be the problem but with the gages going haywire, im thinking electrical. grounds, bat terms, condition of battery, alt charging properly....
    08 grand prix NA3800
  3. Likes Zulu Kono liked this post
  4. #3 Re: Mix of Weird Symptoms
    St. Louis
    Pull both battery cables and clean them and the battery connections. When reassembling make sure they are nice and tight. A loose negative cable can cause this as I've had it happen on my 00 GT.
  5. Likes Zulu Kono liked this post
  6. #4 Re: Mix of Weird Symptoms
    Mar 2018
    NY
    Usually your electronics going haywire is the alternator. I would check your charging system out. With the vehicle off the battery should be reading 12.6 volts. With the vehicle running the battery should be reading 14.6 volts as it would be receiving a charge from the alternator. You can even turn some things on like the lights or ac to put a load on it. If while the vehicle is running the voltage drops below 13 volts the battery is being drained and would cause the vehicle to die. That would be the first thing I check out
  7. #5 Re: Mix of Weird Symptoms
    Mar 2014
    Tucson
    I don't think this guy is worth your time.
    Quote Originally Posted by Zulu Kono View Post
    Phuck that, phuck this place, and go phuck yourselves! I'm out.
  8. Likes Scottydoggs liked this post
  9. #6 Re: Mix of Weird Symptoms
    St. Louis
  10. #7 Re: Mix of Weird Symptoms
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by BrandonHall10 View Post
    wellll now wasnt that a little hissy fit!
  11. #8 Re: Mix of Weird Symptoms
    Mar 2014
    Tucson
    Quote Originally Posted by tomsteve View Post
    I was a little surprised too. Guy got all bent out of shape because he had to wait for post approval.
  12. #9 Re: Mix of Weird Symptoms
    Mar 2018
    NY
    Apparently not lol. If he's gonna have a tantrum over a mod having to approve his post he's definitely not worth our time.
    Hopefully someone else surfing around here finds the info useful.
  1. Bizarre Symptoms
    By Hurricane87 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-15-2020, 10:49 AM
  2. PS Pump Symptoms?
    By luckyg817 in forum General Grand Prix Discussion
    Last Post: 03-23-2015, 05:04 PM
  3. Weird symptoms... Loss of power, hard shifts, random downshifting
    By Xorbex in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-28-2014, 04:09 AM
  4. Low Oil Pressure but no symptoms?
    By EJOUIE in forum General Tech Discussion
    Last Post: 06-09-2011, 09:10 PM
  5. Are these symptoms of a bad hub assembly?
    By nawarkk in forum General Tech Discussion
    Last Post: 02-18-2010, 09:28 PM
