Thread: strange electrical issue
Results 1 to 8 of 8
  1. #1 strange electrical issue
    Apr 2014
    commerce twp,mi
    '08 base model. not every time, but a few times over the last 2 months, while driving the power has cut out for a split second. headlights, dash lights, stereo, everything. it happens so quick i dont know if the engine dies. its like flipping a wall switch for a light off the back on pretty quick. tach and speedometer do its startup jump,the display in the dash goes through its start up thing, and seat belt dinger dings like on start up.
    i havent done any digging more than cleaning the battery terminal so far and hopin i might get some things to look at.
    08 grand prix NA3800
  2. #2 Re: strange electrical issue
    check the small grounds on the trans bell housing, same place the neg cable bolts to. the wires start to break off the eyelets, you hit a bump and the wires move and power drops and comes back.
  3. #3 Re: strange electrical issue
    hangover park IL
    its very likely the ignition switch.
    if you have more than a couple keys and fob on your keychain, remove em, the less weight the less likely it is to happen
    ~James~ Psychotic Gearhead
  4. #4 Re: strange electrical issue
    Apr 2014
    commerce twp,mi
    ya ever been laying in bed- just about to fall asleep and something hits ya?
    happened to me last night. thinkin about the grounds ya mention wondering why they may be a problem.
    then it hit me- just as i was about to fall asleep. i had trans work done a few months ago. the problem started after that.
  5. Likes Scottydoggs liked this post
  6. #5 Re: strange electrical issue
    Jan 2021
    Ohio
    Good call Scottydoggs.
    Op, let us know what you come up with.
  7. #6 Re: strange electrical issue
    Apr 2014
    commerce twp,mi
    update:
    finally had warm enough weather to get my baby on jack stands, do some other work, and check out grounds.
    i put new pos and neg terminals on the battery as they had been used and abused plus checked the ground on the trans. removed the paint on the trans, cleaned up the ground terminals, put it back together, have driven about 500 miles, and havent had the issue return so far.
  8. Likes Scottydoggs liked this post
  9. #7 Re: strange electrical issue
    Jan 2021
    Ohio
    Good job. Thanks for the update. ls is still working OK?
  10. #8 Re: strange electrical issue
    Apr 2014
    commerce twp,mi
    Quote Originally Posted by mrbreezeet1 View Post
    hadda little elec issue since but cleaning the bat terminals and greasin em up took care of it.
  1. Strange electrical issues
    By mxthunder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-20-2015, 11:54 AM
  2. strange issue
    By GTP Push in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-07-2011, 03:16 PM
  3. Strange electrical problem
    By techweenie in forum Audio, Security & Visual Electronics
    Last Post: 11-08-2010, 10:37 PM
  4. Strange interior electrical/light problem
    By frozenlead in forum Audio, Security & Visual Electronics
    Last Post: 08-13-2009, 01:04 AM
  5. strange issue?
    By GTPJOE90 in forum General Tech Discussion
    Last Post: 06-29-2008, 12:27 AM
