#1
Any ideas why this would sound like this?
#2
Re: Any ideas why this would sound like this?
BalboaNYC
Either buy a mechanics stethoscope and place the tip on each accessory, or loosen or remove the belt and spin all the pulleys by hand checking for play and noise. Wiggle each pulley to check for play. Spin the pulleys as fast as you can by hand. That's usually the best way to find the noise.
Post Thanks / Like - 0 Thanks, 1 Likes, 0 Dislikes
#3
12-20-2021
sounds like the ac clutch went bad. if the ac works when you turn it on that sound should stop.
98 Buick Regal GS, F body brakes, Caddy STS wheels, tinted tails
L36 bottom end, lightly ported heads, 1.95 roller rockers, headers, gen 5 N* 3.0 pulley, FSIC, 42 lb injectors, a BrandonHall rebuilt trans, DHP tuned and AEM water/Meth injection https://goo.gl/gpV5kW
