Thread: Radiator fan issues
Results 1 to 2 of 2
  1. #1 Radiator fan issues
    Aug 2021
    Texas
    Hope I can explain my issues....
    So I noticed my car temperature was going over 3/4...after I had a mechanic switch out the Rack and Pinion.
    I'm in South Texas....I know it gets pretty hot in the afternoons.
    Wanted to check the fans and noticed 1 wasn't working.
    I checked the relays and we're all good. Non-issue/problem there. I thought it was the fan motor that wasn't working. So I switched the connectors from one fan to the other to see if it worked. It didn't work. So I assumed it was the radiator fan motor the was busted. I wanted to check the coolant sensor that I replaced about a year ago. And noticed something disconnected. The plug was between the rack and pinion and the transmission....I connected it and both fans worked. Turned on as soon as I started the car.
    I thought my troubles were done but the next day the same fan wasn't working again. Checked if there was any current going through the cables/wires. Theres no power going to the fan.
    Anyone know any tips on how to fix this issue?
    Note: Thermostat was changed about a week after coolant sensor was replaced. It's been about a year already.
    Also replaced the water pump a day before this post.
    Any tips/help will be greatly appreciated.
  2. #2 Re: Radiator fan issues
    Mar 2018
    NY
    Sounds like something with the wiring. You have the harness coming off the car (probably part of the engine harness) which goes to a connector on the fan assembly. From that connector there is another small harness that Y's off to both fans. I had an issue with that Y-harness to where only the driver's side fan was running. If I jiggled that harness the passenger side fan would run, however it was only temporary. I found a replacement harness from someone on the facebook marketplace that was parting out and its been working since. I would start at the fans and work my way back.
  1. 01 Radiator
    By indygrandprix in forum For Sale - Parts
    Last Post: 11-17-2013, 03:33 PM
  2. Radiator
    By kissmyss in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-15-2013, 07:40 PM
  3. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  4. Radiator Cap??
    By RegorHtims in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-13-2011, 10:18 AM
  5. Radiator Cap
    By mongoclark in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-12-2010, 12:10 PM
