Thread: Front end noise? Transmission?
Results 1 to 3 of 3
  1. #1 Front end noise? Transmission?
    canal winchester, ohio
    Anyways, both wheel bearings and cv axles have been changed out in last 20k miles prior to noise. I am aware of checking wheel bearing noise by making high speed turn and seeing if noise goes away. No clicking when turning which I think indicates cv axle issue.
    Either tires or transmission issue is my guess. I rotated tires and noise is still constant. Noise is constant whether in drive or in neutral.
    I dont know at this point. Might change out the cv axle or just wait for complete failure.
    Thoughts?
  2. #2 Re: Front end noise? Transmission?
    May 2020
    Pittsburgh
    It wouldn't be the first time w-body wheel bearings only last 20k. I wouldn't count that out yet.
    Easiest way to check is lift the front end and spin the wheels individually, that will at least pinpoint which side it's on. After that, a mechanic's stethoscope or long screwdriver becomes your friend.
  3. #3 Re: Front end noise? Transmission?
    Thanks
    I did order a wheelbearing already to start the elimination process
  1. Transmission noise at idle
    By ice2484 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2018, 08:02 AM
  2. Transmission is making noise
    By GTPpower in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-16-2014, 05:09 PM
  3. New front brakes and now a squeaking noise up front
    By Trann14 in forum Brakes/Suspension/Chassis
    Last Post: 05-30-2013, 08:45 PM
  4. Transmission Noise
    By ZRL611 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-09-2013, 06:12 PM
  5. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
