Thread: Odd cooling system trouble
Results 1 to 3 of 3
  1. #1 Odd cooling system trouble
    Dec 2020
    Glenavon,Sk,Can.
    Ok. New here so hey everyone. I’ve been searching the threads for this one and can’t find anything close enough. I have an 07 3800 Grand Prix. The fans won’t come on when The engine is hot. I am able to command them with my scanner and they work fine but when the car gets hot they won’t come on and also the gauge stays low even when the data stream reads the ECT reads 210° plus. Everything else seems to check out. Relays and fuses are good and ETC sensor check out with multi meter. ANY IDEAS??
  2. #2 Re: Odd cooling system trouble
    St. Louis
    Have you tried disconnecting the ETC sensor and see if the fans run on high? Also, turn on the A/C and see if the fans come on.
  3. #3 Re: Odd cooling system trouble
    Dec 2020
    Glenavon,Sk,Can.
    I did both as i was rechecking the resistance on the ect. Actually found they do come on consistently at 220. I sort of remember seeing that somewhere in the literature but can’t find it again. Hoping for the best now. Gonna change the cluster anyway cause the gauge is out. Thx for the reply.
  1. Having trouble bleeding the cooling system
    By LHRxXD3adXx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2014, 06:49 PM
  2. Cooling system help
    By 2006GrandPrixGT in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2014, 01:59 PM
  3. Cooling System Help
    By DrKavorkien in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-13-2012, 01:10 AM
  4. Air in Cooling System?
    By tuchek in forum General Tech Discussion
    Last Post: 02-06-2012, 07:04 PM
  5. Cooling System
    By kcfalcon2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-30-2011, 01:44 PM
