Thread: Need help with codes on 08 Pontiac GP 3.8L !!
Results 1 to 4 of 4
  1. #1 Need help with codes on 08 Pontiac GP 3.8L !!
    Oct 2020
    Inland Empire California
    hello i recently went to auto zone and had them run the obd2 to check for any codes & my car came back with PLENTY .. I’m learning how to fix this car as I use it so I don’t have to pay as much and so I can gain some knowledge !! But it’s getting to hectic and confusing ! These are the codes as of right now .. P0306 , P0054 , P0102 , P0141 , P0412 , P0418 ,P0443 , P0446 .. my car has roughly 190,XXX miles on it 😟 . I’m currently changing the spark plugs and just did an oil change yesterday . Need a list of the things from auto zone so I can have my car running right again !! If you guys have any answers lmk please !
  2. #2 Re: Need help with codes on 08 Pontiac GP 3.8L !!
    Mar 2014
    Tucson
    Give us a brief description of each one of those codes. There's a lot of guys willing to share knowledge, but they're not going to do the leg work.
  3. #3 Re: Need help with codes on 08 Pontiac GP 3.8L !!
    GT Level Member mguzzo's Avatar
    Buffalo NY
    wow, how is it even running with that many codes popped?
    P0306 misfire on cyl 6
    P0054 Rear O2 heater circuit
    P0102 MAF circuit low
    P0141 Rear O2 heater circuit
    P0412 AIR injection malfunction
    P0418 Secondary air injection pump relay A -circuit malfunction
    P0443 EVAP purge circuit malfunction
    P0446 EVAP incorrect purge flow
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  4. #4 Re: Need help with codes on 08 Pontiac GP 3.8L !!
    I would bet there's a common power circuit here. First step is check all the fuses and replace the one that is blown. Then take a look at your #6 plug wire for a mark on it where it's likely laying on metal and arcing out.
    Did a little wire diagram reviewing and everything you mention except cylinder 6 misfire has common power supply.
    Powertrain relay #40 feeds two fuses numbered 10 (Emission) and 14 (O2 SSR) in the fuse box.
    Check the relay/fuses above and that plug wirre and you should be all fixed up
  1. 1999 pontiac grand prix gt trailer hitch onto 2008 pontiac g5 gt ?
    By thomasd2010 in forum General Grand Prix Discussion
    Last Post: 02-17-2013, 11:47 AM
  2. codes codes codes gotta love them!
    By 19GTP98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-31-2012, 02:13 PM
  3. pontiac on pontiac kill
    By chromeg6 in forum Track Sessions and Kills
    Last Post: 04-29-2011, 09:39 AM
  4. New member and first time Pontiac Grand Prix owner (first pontiac ever)
    By Lexiconix in forum Introductions/Noob Questions
    Last Post: 11-10-2010, 09:45 PM
  5. GM RPO Codes
    By mkuhn20 in forum General Tech Discussion
    Last Post: 01-21-2009, 04:47 PM
