Thread: Mysterious starting issue
Results 1 to 2 of 2
  1. #1 Mysterious starting issue
    MD
    Hi: 1999 GP, original owner.
    My wife called and said the car wouldn't start. It was completely dead, no accessories, no ignition. The key could not be removed from the lock.
    I pulled out the jumper cables, but as I was about to attach the black clamp to the chassis, I jiggled one of the cable harnesses under the fuse panel next to the battery and I heard the door chime!
    I asked her to try and start the car and it started right up!
    Jiggled the cable some more and the car wouldn't start. After a while and more jiggling, it started again.
    Obviously a loose wire behind the fuse block ... but which one? The ignition relay and the main ignition fuse are on the RHS of the block, second sub-block from the bottom. Does anyone have a wiring diagram that shows which wire could be causing this type of symptom - the key is in the on position, but the car behaves like it's off???
    Thanks.
  2. #2 Re: Mysterious starting issue
    Jan 2014
    AR
    Had that happen to me one day in the GT, it was loose big red wire under the nut at the + jumpstart terminal on top of the "electrical center". Like you, I wiggled stuff then aha!
  1. Starting issue.
    By 98buicksupercharged in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-10-2014, 08:44 PM
  2. Starting Issue
    By GrandPriest24 in forum General Grand Prix Discussion
    Last Post: 03-02-2013, 02:23 PM
  3. Mysterious intermittent smoking Issue Solved-
    By 02 WS6 TA in forum General Tech Discussion
    Last Post: 03-15-2012, 06:36 AM
  4. Starting issue
    By GTP Ryan in forum General Tech Discussion
    Last Post: 08-28-2011, 02:55 AM
  5. 04 starting issue
    By peppy in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-06-2010, 02:45 AM
