Thread: Need sway bar help
Results 1 to 8 of 8
  1. #1 Need sway bar help
    Hamilton OH
    I have a 02 gp gt. I have the Dorman 33mm bar and it hits and bends the tie rods. Do I have the wrong bar or is mounted wrong?
  2. #2 Re: Need sway bar help
    St. Louis
    There should have been a sticker or marker on the the bar stating which side was down. Not sure what happens if you mount it upside down but you might want to double check it. I've installed a few a these bars on different 97-03 cars and never had an issue.
  3. #3 Re: Need sway bar help
    HUDSON
    What end links are you using to connect the bar to the a-arm?
    I ask this because if the end links are too long, it could definitely position the bar to the point it could make contact with the tie rods.
  4. #4 Re: Need sway bar help
    Hamilton OH
    ACDelco 46G0114A Advantage Front... Robot Check
  5. #5 Re: Need sway bar help
    SE Level Member ThatOldCarSmell's Avatar
    Apr 2020
    Upstate SC
    FWIW, I thought the end links were a little long with my kit too (they came with the zzp sway bar that I bought), but when I put them beside my oe's they were the same length. Also, some folks (myself included) choose to flip the sway bar upside down to allow a little more room for a larger diameter dp. I sized mine up both ways, and the ends were not close to the tie rods either way.
    99 GTP:
    ZZP FWI , ZZP 3" catted DP, Resonator delete,The occasional Poly bushing, ZZP front sway Bar, NGK TR6's, LED Headlights, 180* TStat, Anti- pogo washers ...This list seemed a lot longer before I started typing....
  6. #6 Re: Need sway bar help
    SE Level Member Xerosiv's Avatar
    Jun 2020
    Justin, Texas
    What part number for the bar? Should be 927-100.
    You have it in already and it hits or you are trying to put it in and it hits? Do you have a pic by chance?
  7. #7 Re: Need sway bar help
    Jan 2021
    Ohio
    Well what was the problem I'm curious now?
  8. #8 Re: Need sway bar help
    Feb 2020
    MN
    replaced sway bar on mine with kit from rock auto....now my cat is touching the new sway bar. Was work getting it in , theres just not a lot of room. middle of bar bends upward as oem one did. but new bar is heavier and may even be a bit bigger. ???
  1. Broken front sway & alignment ? Also sway bar recommendations..
    By Exile in forum General Tech Discussion
    Last Post: 10-14-2016, 12:24 PM
  2. Sway bar
    By mofford12 in forum Wanted To Buy - Parts
    Last Post: 07-30-2013, 05:51 AM
  3. 03 Sway Bar Help
    By Below Average Joe in forum Brakes/Suspension/Chassis
    Last Post: 09-23-2011, 08:22 AM
  4. sway bar
    By BoostJunki3 in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 02:38 PM
  5. Help on Sway bar
    By Vetolien in forum Brakes/Suspension/Chassis
    Last Post: 03-18-2009, 12:08 PM
