Thread: 2007 grand prix GT
Results 1 to 6 of 6
  1. #1 2007 grand prix GT
    GTP Level Member
    Oct 2014
    So have antifreeze getting flung around the engine compartment by the waterpump pully and belt.
    Took a quick look and Top elbow is metal and dry at connections. 195000 miles.
    What to check first? Im guessing waterpump but might gather some parts before i dig i.
    I did the timing cover gasket a couple years ago so im pretty sure its not that. Probably should have done the waterpump then but i am kind of cheap and like to get the full useful life out of stuff.
    Thanks for ideas.
  2. #2 Re: 2007 grand prix GT
    GTP Level Member
    Oct 2014
    I will have a water pump on hand when i dig into this on wed or thur.
  3. #3 Re: 2007 grand prix GT
    Apr 2014
    commerce twp,mi
    reads like WP seal/bearing. might wanna have some new elbow o rings handy when ya replace it. i think you can get the plastic elbows at AZ and use them o rings
    08 grand prix NA3800
  4. #4 Re: 2007 grand prix GT
    I would have replaced the gasket only if that was the only issue at the time. Replacing a good part for no reason isn't my idea of fun.
    It's not bad to do the pump only.
  5. #5 Re: 2007 grand prix GT
    GTP Level Member
    Oct 2014
    I will keep you posted. Both elbows are fairly new metal so i am assuming they will still be good.
  6. #6 Re: 2007 grand prix GT
    GTP Level Member
    Oct 2014
    Threw in the waterpump last night.
    No real indications that the old one was bad other than inside of pulley had a layer of damp dex sludge even though green has been in for years.
    Still drains out as a brownish orangish green.
    Not the original pump so someone before me put one in. It Had really small vanes. The new delco pump had much larger vanes. They did use a metal gasket.
    Put the new delco pump, new metal gasket, re-lubed the metal elbow o-rings and bolted her together.
    So far no leaks so thats a plus!
  7. Likes tomsteve liked this post
  1. FS 2007 Grand Prix GT S/C
    By hotdogstand in forum For Sale - Vehicles
    Last Post: 07-19-2018, 07:30 AM
  2. 2007 Grand Prix GXP
    By tomtom123 in forum Brakes/Suspension/Chassis
    Last Post: 06-22-2017, 03:22 PM
  3. My 2007 Grand Prix GT
    By carlover89 in forum Members Rides
    Last Post: 01-07-2012, 03:02 AM
  4. 2007 Grand Prix
    By kristinkay in forum Introductions/Noob Questions
    Last Post: 07-29-2010, 02:23 PM
