Thread: 2005 gp gxp no crank - no start --- help
Results 1 to 11 of 11
  1. #1 2005 gp gxp no crank - no start --- help
    Nov 2019
    Wi
    2005 GP GXP ... Turn ignition key to start ... nothing happens !
    No power to starter relay or starter...
    HELP !!!
  2. #2 Re: 2005 gp gxp no crank - no start --- help
    Apr 2014
    commerce twp,mi
    hows the charge in the battery? hows the connections at the battery?
    08 grand prix NA3800
  3. #3 Re: 2005 gp gxp no crank - no start --- help
    Nov 2019
    Wi
    new battery ... connections ok ... all else works good !
    Starter does work with a jumper wire from battery to starter relay ...
  4. #4 Re: 2005 gp gxp no crank - no start --- help
    Nov 2013
    pittsfield ma. 01201
    Possible ignition switch problem
  5. #5 Re: 2005 gp gxp no crank - no start --- help
    Nov 2019
    WI
    Could be a lot of things. Where are you located in Wis? I am south of Milwaukee. Does the check engine light illuminate on the dash? Is the security light flashing? Is the start or crank fuse blown?
  6. #6 Re: 2005 gp gxp no crank - no start --- help
    Nov 2019
    Wi
    I am about 200 miles north of Milwaukee.
    It is my son's car.
    No check engine light ... or security light ... & starter fuse is good !
  7. #7 Re: 2005 gp gxp no crank - no start --- help
    Nov 2019
    WI
    Could be a bad starter relay in the under hood fuse box. Pop the relay and see if there's power on one of the terminals when you turn the key to crank. If there is suspect a bad relay. There are also fusible links that could be blown. Also bad grounds by the battery and on the trans. I guess there is power to the relay at all times if the fusible links and fuses (more than one) are ok. Good luck and let us know what you find out.
  8. #8 Re: 2005 gp gxp no crank - no start --- help
    Nov 2019
    Wi
    SOLVED !!
    It was the ECM IGN fuse ... was loose in holder (in under hood fuse panel) ... squeezed together ... & it starts right up !!
    Thank you all for replies / responses !
    GRAND PRIX GXP on !!
    go GP GXP go..o..o..o...
  9. #9 Re: 2005 gp gxp no crank - no start --- help
    Nov 2019
    WI
    Hey Hey! Glad you got it fixed and it was something simple and free!
  10. #10 Re: 2005 gp gxp no crank - no start --- help
    Nov 2019
    Wi
    Yeah ... that is the best part !
    I can't imagine what the cost would be at a dealership or repair shop !!
  11. #11 Re: 2005 gp gxp no crank - no start --- help
    Nov 2013
    Glad it was a easy one wish they all could be so simple
  1. No start or crank plz help
    By Toocidnab in forum 04+ Specifics
    Last Post: 11-19-2017, 12:43 PM
  2. No crank no start.
    By Undead auto in forum Engine
    Last Post: 02-26-2017, 04:42 PM
  3. No Crank, No Start
    By Tsnoop05 in forum General Tech Discussion
    Last Post: 02-18-2016, 08:26 PM
  4. Crank, but no start
    By JoshMcMadMac in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-24-2010, 11:28 PM
  5. No Crank - No Start!!
    By coolken84 in forum General Tech Discussion
    Last Post: 03-05-2009, 10:15 AM
