Thread: ZZP 3.5" Pulley Kit Questions
Results 1 to 16 of 16
  1. #1 ZZP 3.5" Pulley Kit Questions
    Aug 2018
    NJ
    Hi, I'm looking to get a little more boost out of the supercharger. I'm a student so I need to drive it everyday and can't afford to blow the engine up. I found this ZZP Stage 1 Kit that comes with a U-bend delete, new spark plugs, new PCM, 180* thermostat and a K&N drop in filter which I don't need cause I have a cold air. It's only $350 with a core charge... Not sure if it'd be cheaper to buy everything separately but that price sounds good to me. What I'm not sure about is having a 3.5" pulley with the stock exhaust manifold. Would I need headers in the front and rear? ZZP sells a powerlog for the front which would be much easier. But, I'd like to try and get away with stock if I can. 2003 GTP by the way. I'm still a noob so any advice would be great! Thanks!
    Stage 1 Performance Package for 3800 – ZZPerformance
  2. #2 Re: ZZP 3.5" Pulley Kit Questions
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Please don't buy stage kits for these cars.
    I have no idea what year your car is. If it's on its original catalytic converter, it should probably be replaced anyway. It's been perpetuated this season that ZZP's downpipes are cheaper than an OEM. No longer true ..unless you need the CA specific one that's like 300 dollars. ebay has em about $140 delivered, depending on vehicle. These will have no ubend.
    Plugs are cheap. I'd suggest copper for increased boost. Many will disagree with this, but there are valid reasons to use copper. I run NGK tr6 right now.
    You'll need a tune to safely drop sizes. A canned tune from ZZP or wherever is fine for a slight pulley drop. Don't do it if you find yourself short some weeks and throw in 87 octane.
    Ethanol is another option that's more bang for buck. But you get less mpg, and the ethanol "cons," if you will. (ie. environmental concerns) Personally, I believe that route to be a little simpler and more cost effective, but I don't run ethanol out of personal choice.
  3. #3 Re: ZZP 3.5" Pulley Kit Questions
    May 2008
    Schuyler, NE
    Lol. What possible reason would you have for not running ethanol due to environmental impacts?
  4. #4 Re: ZZP 3.5" Pulley Kit Questions
    e85 burns cleaner and is a renewable source of fuel.....almost no impact to be found. wish they sold it here, id be all over it.
  5. #5 Re: ZZP 3.5" Pulley Kit Questions
    Oct 2014
    portland oregon
    In case your bored
    The Pros and Cons of Ethanol Fuel
    Sent from my SM-N920V using Tapatalk
  6. #6 Re: ZZP 3.5" Pulley Kit Questions
    Aug 2018
    NJ
    I'm not looking to run ethanol lol. I don't even know where I'd get it around here and I need this thing as a daily driver to get me to school. Its been running 93 octane since it was new and I haven't slipped up yet. If I shouldn't buy a stage kit, what do you guys recommend? I won't being doing this all at once, it will be a gradual process of saving money for the next part. It's a 03 GTP with 81,000 miles on it right now and the previous owner had a new exhaust put on but it's stock. Looking at other threads like "Safely modding your 3800 car" I think that a 3" downpipe and a front powerlog would free up a lot and wouldn't be super expensive. Do the cheap ebay downpipes fit okay or is there a brand I should search for? And what about the rear exhaust manifold? Is that okay to leave stock? In that 3800 thread the guy said that the ZZP PCMs are crap so is it best to avoid them?
  7. #7 Re: ZZP 3.5" Pulley Kit Questions
    May 2008
    Schuyler, NE
    The exhaust is in no way a restriction. If you truly want the car to be as reliable or more than it is now, you need to cool the air charge. If you cant get e85, your best option is an intercooler or meth injection.
    There is nothing wrong with a zzp tune, other than the fact that it's a canned tune. A custom tune is going to perform better, but it's also harder to get and usually more expensive.
  8. #8 Re: ZZP 3.5" Pulley Kit Questions
    Jul 2017
    macomb mi
    my first mods were sd headers $227 on ebay shipped and the zzp tune with emissions codes removed and obviously smaller pulley. might cost you $400 to $450 altogether but is EASILY worth the extra $100 over that kit. IMO its worth it if it was double its price lol. and I made a intake for $15 from a junkyard but it just makes the supercharger as loud as a blown Camaro haha little to no performance gain
    2004 gtp SD headers, e85, #60 injectors, Walbroh 255lph, junkyard custom fender well intake, lq4 MAF, 2.8 Pulley, 1.95 rockers, l76 springs, ssic w/ vw rad shift kit and tranny cooler 275/45r17. BMR trailing and rear control arms, zzp STB's, tubular control arms, Dorman and Addoco sway bars, intense coilovers, all poly. avid av-20s
  9. #9 Re: ZZP 3.5" Pulley Kit Questions
    May 2016
    MN
    Quote Originally Posted by superdev View Post
    If I shouldn't buy a stage kit, what do you guys recommend? It's a 03 GTP with 81,000 miles on it right now and the previous owner had a new exhaust put on but it's stock.
    I'd leave it stock. Start at the brakes and move onto replacing the OEM suspension with GM parts. It's a nice car.
    If you're dead set on getting more power without some sort of cooler, look at a cam or higher ratio rockers as alternatives. I'd choose the cam and pick a grind for my style/needs.
  10. #10 Re: ZZP 3.5" Pulley Kit Questions
    Jul 2017
    macomb mi
    Quote Originally Posted by SaukRapids View Post
    this is true I started at the suspension didn't keep the stock suspension though then did the power and then some F-body brakes. very first thing I did to the car was get akenbo brake pads though best pads IMO absolutely no dust absolutely no noise small stopping power improvement over stock and last FOREVER rears are still at like 40% 70k miles later and had to do fronts still got a good amount to since when I got the f body brakes I used new akenbo pads as well. but this guys going to school lol I wouldn't say cam or rockers would be the best idea. rockers alone took me the whole weekend and ive done them before on a DOHC didn't even run into problems this time around a cam would take me even longer I assume this guy dosent want to get that involved only reason I did it is because I got some 1.95 rollers for the price of 1.9 modifieds
  11. #11 Re: ZZP 3.5" Pulley Kit Questions
    May 2016
    MN
    Well, if you're going to speak for him. Then remind him that this game is pay to play.
    Week, weekend, we park our car during the winter.. no time frame was given. If you just want to hero up an SJW attitude, I suggest you return to fb.
  12. #12 Re: ZZP 3.5" Pulley Kit Questions
    Jul 2017
    macomb mi
    I don't know what an SJW attitude is im just speaking from someone whos in school also and needs the car to drive everyday and not break down as he clearly stated in the second sentence and I wouldn't say a grand prix is pay to play until your talking about a turbo kit or enough power to need a new transmission and I never mentioned price as an issue regardless so I don't know why that was even brought up when I was saying involved I meant long downtimes and now that im reading he said he needs to drive the car EVERYDAY so one would assume the time frame he was giving is 1 day maybe a weekend if hes free
  13. #13 Re: ZZP 3.5" Pulley Kit Questions
    May 2008
    Schuyler, NE
    I was in college when I did my first cam swap on a my car. Started at 2 on a Friday afternoon and finished at noon on Saturday. Also installed headers at that time too.
  14. #14 Re: ZZP 3.5" Pulley Kit Questions
    if you're relying on the car as a DD get an auxiliary trans cooler to cool the trans fluid to prolong the trans. after that, then slowly piece together parts for the motor side for power.
    homemade fenderwell intake (FWI) Air intake can be made for cheap
    dropping to a smaller pulley would be the last things to do
    canned tune from zzp or local tuner that is set up for the pulley you'll eventually drop to like a 3.5".
    some sort of exhaust setup, either powerlogs and 3" downpipe with u-bend delete or go headers
    then pulley down. don't forget the proper tools to get the stock pulley off. may want to invest in a modular pulley system (MPS) instead of the press-on if you plan on swapping to larger or smaller pulleys. look up vender name nate herbst (he's on ebay and fb groups)
  15. #15 Re: ZZP 3.5" Pulley Kit Questions
    Jul 2017
    macomb mi
    dang gtpower it took me around the same amount of time on the rocker install although I did the springs with a rope and spent some time going back and forth getting tools from my apartment haha and I agree with the trans cooler as well did one when I got a new radiator and I firmly believe my trans would've blown by now if I didn't went from 230+ temps down to 170 MAX thing was showing signs of going before and has somehow gotten progressively better since the install even with added power
  16. #16 Re: ZZP 3.5" Pulley Kit Questions
    Aug 2018
    NJ
    Quote Originally Posted by fst View Post
    Thanks for the help. This is probably what I'll do. Need to drop the pan on the trans and replace the fluid anyway since I didn't do that when I got the car a year ago. I think I'll also get a 180* thermostat and new spark plugs with a higher heat range. Then powerlogs and 3" downpipe w/ ubend delete and finally like a 3.5" pulley with a MPS.
    Gonna take a while til I plan out enough money and time to do this lol. But, Trans cooler seems like something that's good for even stock GPs. So, I'll probably do that soon. I have a bunch of other stuff to take care of on the car first. Like trying to find the right clips to hold the lower front door trim (I have to put more adhesive on all of the door trim now that I think about it), resistors for my LEDs switchbacks and blacking out the reflectors on new side lights. I need to make a list.
  1. 3.5 pulley, TB Spacer, PLOG, other "go fast" goodies
    By GTPlzz in forum Wanted To Buy - Parts
    Last Post: 02-13-2014, 04:27 PM
  2. WTB: 3.6" or 3.8" press-on pulley, 3-Guage pillar pod
    By a97GTP in forum Wanted To Buy - Parts
    Last Post: 02-11-2014, 08:03 PM
