Thread: 01 GP GTP - Help w/ replacing power steering pump and lines...
Page 3 of 3 FirstFirst 123
Results 41 to 45 of 45
  1. #41 Re: 01 GP GTP - Help w/ replacing power steering pump and lines...
    you can do it from the front, you just wont be doing as well of a cleaning. that screen comes off, theres a snap ring holding it in there, then use a tooth brush and brake cleaner open the blade and get in there, you want to clean the back side of the blade too. then wipe it all down nice with a rag best you can.
  2. #42 Re: 01 GP GTP - Help w/ replacing power steering pump and lines...
    Chicago
    I took a stab at this earlier tonight. Just took off the snap ring and tried cleaning from the front. Used some carburetor cleaner and a rag and cleaned it as best as I could from the front. I can see that it would be easier with the TB out of the car but then I would need a new gasket. Still need to try and clean the EGR.
  3. #43 Re: 01 GP GTP - Help w/ replacing power steering pump and lines...
    HUDSON
    Most important when cleaning the throttle body is to make sure you inspect and if necessary clean the passage way for the IAC (idle air control) valve. This passage way, along with the pintle seat builds up with carbon and causes funky idle, remove the IAV from the throttle body very carefully not to bugger up the pintle valve, the pintle valve itself must also be cleaned too, an old toothbrush and carb. cleaner/brake cleaner works great to get into both sides of the passage ways. Carefully clean the end of the pintle valve taking care not to push, pull, turn, or change it's position, replace or inspect the o-ring on the IAC, a little oil on the o-ring helps prevent pinching on re-installation.
  4. #44 Re: 01 GP GTP - Help w/ replacing power steering pump and lines...
    Chicago
    Quote Originally Posted by QUICKSILVER462 View Post
    If my idle is smooth, should I even bother with attempting to remove? Wondering if I should attempt to clean the EGR first?
    Also, I saw some posts about having a bad MAP sensor. How would I know if I have an issue with that? Car does run and idle smooth. My concern has been around fuel economy and a random check engine light for P1404 after getting the power steering issues worked out.
  5. #45 Re: 01 GP GTP - Help w/ replacing power steering pump and lines...
    HUDSON
    Before I cleaned my TB, the idle was still smooth, during cleaning I found the IAC port was megga dirty with build up, as was also the IAC pintle, I had a random off idle stumble that has cleared up after cleaning the TB, yours may be different, doesn't hurt to take a look while it is off the car for cleaning, and the o-ring should be able to reuse, but it would not hurt to have a spare handy just in case. Just be careful not to bugger up the pintle valve itself.
  1. Replacement power steering lines
    By bing98 in forum Brakes/Suspension/Chassis
    Last Post: 06-30-2017, 06:43 PM
  2. What are these lines? Transmission? Power steering?
    By Drive XR7 in forum General Grand Prix Discussion
    Last Post: 10-17-2015, 09:49 AM
  3. Replacing power steering pump + hoses (2001 Grand Prix GT)
    By DarkLord in forum General Grand Prix Discussion
    Last Post: 10-28-2014, 01:56 PM
  4. power steering lines
    By hardrocrick1 in forum For Sale - Parts
    Last Post: 03-08-2014, 02:41 AM
  5. Replacing Power Steering Pump
    By AGP in forum General Tech Discussion
    Last Post: 07-11-2013, 05:30 PM
