Thread: Catalytic rattling?
Results 1 to 18 of 18
  1. #1 Catalytic rattling?
    Jun 2018
    Lehigh Valley
    Does or can a catalytic converter rattle when it's going bad? It sounds like a loose heat shield and only happens under light acceleration up to 2k rpm's. I can't find anything loose under the car. The car isn't suffering from any of the usual performance issues when a cat goes bad and there aren't any check engine lights except for a recent P0455 large evap leak. The rattling has been happening for a while.
    '97 Grand Prix GT Coupe
    '05 Grand Prix GTP Sport Red Metalic SOLD
    '05 Grand Prix GTP Silver
  2. #2 Re: Catalytic rattling?
    it could, get under the car and bang on the cat to see if you hear it rattle.
  3. #3 Re: Catalytic rattling?
    Jun 2018
    Lehigh Valley
    It does sound like there is a rattle coming from the cat when I bang on the exhaust. It won't be a problem if it rattles as long as it doesn't throw a code, right?
  4. #4 Re: Catalytic rattling?
    its gonna clog up on ya one day. so id plan to replace it.
  5. Likes Pursell1911 liked this post
  6. #5 Re: Catalytic rattling?
    Jun 2018
    Lehigh Valley
    Is there a particular cat I should get?
  7. #6 Re: Catalytic rattling?
    Likely there's a shield on the cat.. they like to come loose. Take a look and if it's the shield, clamp it or weld it.
  8. #7 Re: Catalytic rattling?
    theres no shield on the cat, its in the tunnel. it can come loose and rattle.
    what brand depends on your year, 01 up you want a stock replacement, older you can get a hi flow with no issues. 01 up a hi flow cause over fueling and cat codes.
  9. #8 Re: Catalytic rattling?
    There might be
  10. #9 Re: Catalytic rattling?
    Jun 2018
    Lehigh Valley
    I'ts for my '05 GP. I took the tunnel shield off last year because it was about to fall off. I'll look again for a cat shield but I don't remember seeing one. Thanks for the info.
  11. #10 Re: Catalytic rattling?
    dont think the 04-5 have the cat test over fueling issue, i think you could get a cheap hi flow cat installed. or a zzp catted dp or a zzp off road dp and install a cat in it. if you change the dp, may as well get the 3 inch.
  12. #11 Re: Catalytic rattling?
    May 2008
    Schuyler, NE
    Some do, some don't. You're best off with a stock replacement.
  13. #12 Re: Catalytic rattling?
    Jun 2018
    Lehigh Valley
    Well, I found out what the rattling was. The flex pipe just bit it. I have a full cut out now. lol
    Are any of these cats any good? I was leaning toward the Eastern cat.
    2005 PONTIAC GRAND PRIX 3.8L V6 Supercharged Catalytic Converter | RockAuto
  14. #13 Re: Catalytic rattling?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    rev it up and see what happens
    YouTube
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  15. #14 Re: Catalytic rattling?
    Jun 2018
    Lehigh Valley
    Replaced the cat and all is good. No more rattle. What do I do with the old one? Trash or does it need to be recycled somehow?
  16. #15 Re: Catalytic rattling?
    Buffalo NY
    take the cat to a recycle scrap yard, you'll get about $40 for it.
  17. #16 Re: Catalytic rattling?
    my scrap yard offered just the weight. seems these cats are not wanted as much as the diamond shaped cats from the 80's.
  18. #17 Re: Catalytic rattling?
    Jun 2018
    Lehigh Valley
    I'll put it in the pile of rotors and take it all at the same time.
  19. #18 Re: Catalytic rattling?
    now rotors add up, thats #1 steel. id be scrapping my own pile of rotors. thing is you need a pile to make it worth the trip.
    id tell hey i got a cat...what they worth these days? seems its hit or miss these days from yard to yard.
  1. catalytic converter CEL, how to replace catalytic converter
    By scha0786 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 11:53 PM
  2. Rattling
    By redskinman73 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-17-2011, 06:59 AM
  3. Rattling....
    By BoostnBlackGTP in forum Audio, Security & Visual Electronics
    Last Post: 03-08-2011, 10:32 PM
  4. Rattling
    By MajorMilf02 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-02-2011, 06:15 PM
  5. rattling ass
    By 04muscle in forum Brakes/Suspension/Chassis
    Last Post: 10-19-2009, 11:44 PM
