Thread: Front wheel squeak when in reverse
Results 1 to 10 of 10
  1. #1 Front wheel squeak when in reverse
    Jul 2012
    Bloomington, IL
    I have this drivers side front wheel squeak when backing up in my GP. But It doesn't squeak when going forward. I took the caliper and bracket off, cleaned everything including the pads, lubed the slider pins good, and it still squeaks when backing up.
    I jacked the driver side front up again and put the car in neutral, and when I turn the tire backwards, i get the squeaking noise. If i take the tire off and turn the wheel hub backwards, no squeak. It's only when the tire is on the car, and you move in reverse.
    Any ideas?
    **Update - If I turn the wheel all the way to the right, I can tell the squeak is coming from the axle where it meets the engine.
    2005 GTP - Headers, 3" DP, resonator, and catback, CAI, 605 plugs *Sold*
    2016 WRX Premium - Stage 2 E30
  2. #2 Re: Front wheel squeak when in reverse
    Pull the tire and look to see if the backing plate is touching the rotor at all. Likely its the issue.
  3. #3 Re: Front wheel squeak when in reverse
    Jul 2012
    Bloomington, IL
    It's definitely coming from the axle where it meets the engine. Squeaks, and almost sounds like a scraping sound in reverse, but not in drive. The car sat for about a week and a half without moving, and it wasn't squeaking before that.
  4. #4 Re: Front wheel squeak when in reverse
    i just found my bracket that holds the abs plug bent and touching the rotor near the ball joint. it left a scar on the rotor. i beat it out of the way.
    the abs plug was also off the bracket. i think when i got it buried in snow it bent it and pulled the plug off.
  5. #5 Re: Front wheel squeak when in reverse
    Jul 2012
    Bloomington, IL
    Checked out around the rotor, and nothing is sticking there. I can isolate the squeak to the axle where it meets the engine. Sorry if I'm not using the correct term.
  6. #6 Re: Front wheel squeak when in reverse
    Does the axle seal look damaged or anything?
  7. #7 Re: Front wheel squeak when in reverse
    Jul 2012
    Bloomington, IL
    It doesn't look damaged at all. And curious as to why it squeaks so bad only in reverse, and not forward. I would think direction would not matter if it's just spinning around in there.
  8. #8 Re: Front wheel squeak when in reverse
    Jul 2012
    Bloomington, IL
    I've fixed the issue. Sorry guys, it was a flat metal plate on the back side, and bottom of the rotor. I was looking along the top side of the rotor. And that plate was resting on the rotor, but would only squeak when in reverse which was weird. And it sure sounded like the axle was making that noise. Oh well, live and learn. Thanks for all of the input.
  9. #9 Re: Front wheel squeak when in reverse
    what ya know, same area i had rubbing.
  10. #10 Re: Front wheel squeak when in reverse
    Whatcha know.. same thing I suggested. It's common. As for squeaking in one direction, it's probably the edge that was touching and it was getting rubbed the right direction to make the noise.
  1. Car died when put into reverse and turned wheel full to the right
    By Beatdowncity in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-16-2015, 07:13 PM
  2. Squeak from right front/ supercharger question
    By mor99gtp in forum General Tech Discussion
    Last Post: 04-10-2014, 11:42 PM
  3. Loud reverse Squeak!!
    By Rockstar58 in forum Brakes/Suspension/Chassis
    Last Post: 05-21-2013, 05:10 PM
  4. weard squeak ing noize when I turn the wheel
    By rc10gt7090 in forum Brakes/Suspension/Chassis
    Last Post: 03-12-2012, 11:06 PM
  5. Right front Squeak
    By gvandal in forum General Tech Discussion
    Last Post: 12-03-2009, 07:37 AM
