I just bought a 2009 G6 GXP
And the engine took a crap
The engine started knocking a and the car shuts off
So I have a question.
my G6 has the 3.6
Can I install a 3.5 or a 3.9in it
my G6 has the 3.6
No warranty
It expired as soon as I drove of his property
No, you must replace it with a 3.6.
The 3.5 and 3.9 are totally different and will not function with the computer/wiring in the car. The 3.6 is specific to that model and computer/wiring.
Is the Pontiac G6 the only one that has this size motor
That will fit this car
Or is there other GM brands that have this same size motor
Thanks
The LY7 was put in several cars.
GM High Feature engine - Wikipedia
You'd need to find one from another LY7 equipped vehicle, then swap over any brackets or whatever that is different. You will need to do a lot of research to make sure what else you may run into when swapping engines.
While the engine is out please consider changing the timing chains and tensioners. Those High Feature 3.6 Liter engine are infamous for eating the timing chains/tensioners. I was doing research for a friend and was scared away from those engine because the job is just easier once the engine is out of the car and it is more of a maintenance item!!!
Honestly I'd just check car-part.com, LKQ or another JY in the area and see if you can score a good running engine, do the recommended timing chain/tensioners while out and drop it in. That would be the quickest way to get it back on the road with minimal chances of a "surprise" if you don't build it right. Then again, if you have the time/money to properly build it from scratch then by all means, build away!
