Thread: Car dies when turning
Results 1 to 6 of 6
  1. #1 Car dies when turning
    SE Level Member Felix's Avatar
    Jul 2016
    Left the car to run for 2 mins, came back and turned the wheel left and RPM dropped and engine died. Started her back up and she drives fine. Thinking power steering pump is gone and causing too much tension. Any thoughts?
    EDIT: Pump is not whining like mad, steering is a little bit stiff at a stop and low speed.
    Plis Halp
    02 GP GTP "Delphene" in Redfire Metallic
    CURRENT - E85, AEM E85 Pump, 60# SD60, 3.4 pulley, ZZP DP, K&N CAI.
    NEAR FUTURE - 3.2/3.0 pulley, TEP HPS3 TRANS, ZZP 3in catback exhaust.
  2. #2 Re: Car dies when turning
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    That would be my thought. Any codes?
  3. #3 Re: Car dies when turning
    Jul 2016
    SES Light is off but im gonna scan tomorrow to see if theres anything pending.
    Plis Halp
  4. #4 Re: Car dies when turning
    try the hi-speed fuel pump relay mod. basically bend tab 85 and reinstall and see if that helps. when I had my 98 gtp a while back it'd stal whenever I make a 90* turn onto a road, mainly right-hand turns.
  5. #5 Re: Car dies when turning
    Jul 2016
    Luckily the car doesn't shut off when on the move, RPM drops but it hasn't shut off on me anymore. Scanned it and no pending codes. Ordered a new power steering pump as well as a IAC valve just in case, sucks how we just got like 5 inches of snow last night after like 2 months of snow-free weather.
    Plis Halp
  6. #6 Re: Car dies when turning
    May 2016
    Burns City, Indiana
    check for ps switch, many older gm has ps switch input that causes iac to increase rpms at idle. also might get can of ac delco top engine cleaner and can of gumout, and name brand toothbrush, clean depoits out of throttle body and clean iac also.
  1. Power Steering Stiff turning wheel Left Normal turning wheel right.
    By AdrianGTP in forum Brakes/Suspension/Chassis
    Last Post: 01-06-2017, 04:39 PM
  2. Car dies when turning wheel at a stop
    By arlenok in forum General Tech Discussion
    Last Post: 07-01-2014, 09:47 PM
  3. Car turning off
    By Fatboy in forum General Tech Discussion
    Last Post: 12-05-2012, 04:14 PM
  4. Air bag not turning on
    By izup69 in forum 04+ Specifics
    Last Post: 03-13-2011, 05:56 AM
  5. TCS not turning off
    By Keet04GTP in forum General Tech Discussion
    Last Post: 08-06-2008, 02:57 PM
