Thread: Cluster goes out
Results 1 to 4 of 4
  1. #1 Cluster goes out
    Mar 2018
    Canada
    My 2004 grand prix cluster doesnt turn on, after driving for 5 min it will turn on and some times off again. There is no crank on 1st attempt on starting, turn the key off and it starts 2nd time. I changed ignition switch, battery and alt are good. The hot wire on the cluster harness gets 12.4 volts and the switched wire when i turn the key on is only 6.3 volts. All grounds are good. What else can i check? Thank you for help.
  2. #2 Re: Cluster goes out
    May 2016
    Burns City, Indiana
    dOES EVERYTHING FAIL OR JUST THE DIGITAL DISPLAY?
    If just the digital there are couple resistors that fell off the board, google replacing display resistors on youtube. Cast me a pack of resistors 220 ohm if I remember and about 1hr, if whole dash fails might be a cracked pc board.
  3. #3 Re: Cluster goes out
    Mar 2018
    Canada
    Only the check engine light comes on when i turn the key on
  4. #4 Re: Cluster goes out
    May 2016
    Burns City, Indiana
    Quote Originally Posted by 2004prix View Post
    Ok so I missed you year. I have 04 also. When I get to work I'll dig up diagram and take a look. But sounds like power issue at first but don't hold me to that.
  1. 05 Cluster Help
    By Leroyy in forum Audio, Security & Visual Electronics
    Last Post: 10-28-2013, 01:26 PM
  2. Cluster change, will gxp cluster work in a gt? "2007gp"
    By szalajka05 in forum Audio, Security & Visual Electronics
    Last Post: 12-25-2011, 01:02 AM
  3. cluster fu****!!
    By spider4 in forum General Tech Discussion
    Last Post: 11-24-2011, 09:52 PM
  4. Swapping a 3 gauge cluster for a 6 gauge cluster
    By knoppsicle in forum General Tech Discussion
    Last Post: 10-16-2011, 09:49 PM
  5. 05 GXP Cluster in 04 GTP
    By xerxescct in forum General Tech Discussion
    Last Post: 09-30-2008, 03:50 PM
