Thread: Time for some exhaust mods
Results 1 to 10 of 10
  1. #1 Time for some exhaust mods
    SE Level Member Felix's Avatar
    Jul 2016
    So, looking to get some headers. Most likely the SD ones since I heard they pretty much do the same job as the more expensive ones. I've heard about the downpipe being extremely low to the ground, my question is how low? Could anyone possibly post a picture on a GP? Also looking for a full catback exhaust. Could anyone possibly link me to where I can get the stock catback from? Does anyone know if the SD headers work with a ZZP DP?
    Plis Halp
    02 GP GTP "Delphene" in Redfire Metallic
    CURRENT - E85, AEM E85 Pump, 60# SD60, 3.4 pulley, ZZP DP, K&N CAI.
    NEAR FUTURE - 3.2/3.0 pulley, TEP HPS3 TRANS, ZZP 3in catback exhaust.
  2. #2 Re: Time for some exhaust mods
    Jan 2018
    US
    Quote Originally Posted by Felix View Post
    I'm looking for $350 for my SD Headers. Brand new with 0 miles on them! Not even. I have 3 coats of VHT 2000° Silver. Chipped paint is all because I bought the wrong headers. I have an 04 Pontiac Grand Prix Supercharged. Headers only fit 1997-2003 smh, rookie mistake!... Two 3 inch & two 2.5 clamps from ZZP. I have the SD gaskets but it's recommended to buy Felpro gaskets or GM Original... The V band clamp is not in the pic but it's included.
    FYI, the clamps that come with the SD Headers are for sure not recommended. Problems with leaks and deforming the shape of the headers. Definitely create problem if you want to take them off...
    As shown they're wrapped with with the high quality Titanium wrap, making the engine bay super cooler than usual, also keeping heat inside, making the headers seem longer and heat flow faster out. Wrap on the cross pipe will also kee the throttle body cooler. Included, the rest of the role of headrr wrap for the back header along with 6 stainless steel zip ties to finish wrap.
    As you can see, the paint is chipped and not cured or baked on the headers to keep header paint on. That's just ware and tare from trying to make them fit only to realize they're only for (97-03) GTP's, Buick & so on . As well, you can see that they're not used. An obvious shine of newness.
    I live in California and I'm looking for $350
    Everything is brand new!
    Shipping from California.
    Let me know?
    Sent from my SM-N950U using Tapatalk
  3. #3 Re: Time for some exhaust mods
    SE Level Member derpyimp's Avatar
    Nov 2017
    Utah
    I recently installed SD headers in my 04 GTP. I don't have pictures at the moment, but the bend on the downpipe doesn't sit terribly low. It is definitely lower than the stock downpipe, but only maybe an inch lower than the engine cradle. I haven't scraped it on anything yet after over a month. Installation was a huge pain due to rusted bolts and whatnot on the old exhaust coming out. Took me about ten hours in total, by myself.
    Oh, and the SD headers will not bolt up to a ZZP downpipe.
    '04 GTP Comp-G - 14.871 @ 93.30 (6600 ft DA) - 3.6 MPS, SD headers w/ high-flow cat, Gutted stock airbox, Transgo shift kit, AL 104s, 180 tstat, GMPP front sway bar, poly control arm bushings, Tune by Dyno Brian
  4. #4 Re: Time for some exhaust mods
    those headers will fit, i know of many who have em. what part didnt fit right? you might have got a set with a poorly bent cross over pipe. be the only reason they dont fit.
  5. #5 Re: Time for some exhaust mods
    Jan 2018
    US
    Yeah, I tried everything. I'm based in California and no shop wants to touch them. And I can't find anyone who will. So tomorrow, I'm going to have one last go at it. Was told I'll need an o2 bung extension and to re wrap the headers a couple of inches away from the welds to prevent cracking. I'm going to give it one last go.
  6. #6 Re: Time for some exhaust mods
    being your in ca, what you need to do is re use the stock cat to pass inspection, the in and out tubes need to be cut off then cut open to a 3 inch pipe size and welded in, so you can use the header dp.
    if the cross over pipe is the hang up its not bent right, would need a shop or some one who can weld and or bend pipe for ya to fix it.
    you need a o2 extension harness cause it gets moved lower. you also nee to hammer the fire wall so the o2 clears it.
  7. Likes showtastiik liked this post
  8. #7 Re: Time for some exhaust mods
    May 2008
    Schuyler, NE
    I wish I could figure out how to sell something that does not increase performance and causes the owner nothing but headache.
  9. #8 Re: Time for some exhaust mods
    GT Level Member Pursell1911's Avatar
    Jan 2017
    Louisville, Kentucky
    Lol, so you don't recommend headers?
    2006 Grand Prix GT - 3" Downpipe | DIY Intake
  10. #9 Re: Time for some exhaust mods
    May 2008
    Schuyler, NE
    Quote Originally Posted by Pursell1911 View Post
    Correct
  11. #10 Re: Time for some exhaust mods
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Get the headers.
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  1. Post your car scans/time slips here along with mods you have!
    By hollas13 in forum General Tech Discussion
    Last Post: 05-23-2014, 10:08 AM
  2. Fixed my GTP! Time for mods.
    By Konvinced89 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-05-2014, 10:01 PM
  3. Time for a spring tune-up and some basic mods
    By Boosted02GTP in forum General Tech Discussion
    Last Post: 03-11-2010, 10:32 PM
  4. Need opinions on spring time mods
    By bigtom9492 in forum Visual/Body Modifications
    Last Post: 12-13-2009, 10:57 AM
  5. The time for mods are approaching.
    By Merlin in forum Brakes/Suspension/Chassis
    Last Post: 08-02-2009, 11:02 PM
