Thread: Need to stop DIC and HVAC displays from dimming with headlights
Results 1 to 5 of 5
  1. #1 Need to stop DIC and HVAC displays from dimming with headlights
    GT Level Member MyHero's Avatar
    Nov 2015
    OK, so I have an aftermarket stereo and LEDs in the gauge cluster and when the lights come on, the DIC and HVAC displays look really dim.
    Does anyone know which wire should be clipped from each harness to prevent them dimming with the headlights on?
    Thanks in advance. I clipped a wire to the stereo to prevent it from dimming because the cluster LEDs are just amazingly bright.
    MyHero is my pet project, not automotive related
    My car is an 00 GTP
  2. #2 Re: Need to stop DIC and HVAC displays from dimming with headlights
    alternator upgrade will fix that, you could also try the big three power and grounds set up.
  3. #3 Re: Need to stop DIC and HVAC displays from dimming with headlights
    Nov 2015
    Um. Thanks, but no.
    I’m specifically asking which wires to clip to prevent the two displays from dimming with the light switch being on.
    This isn’t a question about a voltage drop or anything but thanks.
    My car is an 00 GTP
  4. #4 Re: Need to stop DIC and HVAC displays from dimming with headlights
    im not help then lol i dont clip wires.....
  5. #5 Re: Need to stop DIC and HVAC displays from dimming with headlights
    GTX Level Member wstefan20's Avatar
    Aug 2017
    Raytown, MO
    The only wires there are to "clip" are the dimming switch wires. They are both grey, but you need to watch out on the radio since there are two grey wires.
    Wasn't aware our displays "auto dimmed", but if that works, then go for it!
    Never had a dimming issue like that, but to back Scotty, I'm not big into cutting wires, and I have the cs144 so I don't have to worry about that....
  1. 97-02 Pontiac Grand Prix Manual Dual HVAC to Automatic HVAC Conversion
    By wstefan20 in forum How To Write-Ups/Tech Tips
    Last Post: 09-05-2017, 11:08 PM
  2. how to stop headlights from bouncing
    By tcman49 in forum General Grand Prix Discussion
    Last Post: 01-18-2013, 02:13 PM
  3. HUD displays a message..?!?
    By tc300 in forum General Tech Discussion
    Last Post: 11-01-2012, 08:59 PM
  4. 1995 GTP ABS light and headlights dimming
    By Adabow12 in forum Brakes/Suspension/Chassis
    Last Post: 08-05-2011, 07:36 AM
  5. HUD only displays speed and blinkers
    By rabithd in forum Audio, Security & Visual Electronics
    Last Post: 04-20-2009, 05:23 PM
