Thread: 02 Grand Prix won't take gas
Results 1 to 4 of 4
  1. #1 02 Grand Prix won't take gas
    GTP Level Member apierce1289's Avatar
    United States
    Alright so I tried to fill my car up with gas and it was almost on E the light was on. Shortly after turning the pump on it started pumping really slow. I tried pulling the nozzle out a little bit and it would still go really slow. Then shortly after putting in about 2 gallons gas started leaking everywhere from what seems to be the filler neck not venting properly. The other day I had no problem putting in a full tank of gas at what would be the normal speed of the gas pump. I tried different angles with the nozzle and all that.
    Sent from my SM-N900V using Tapatalk
    Gremlins always seem to show up in pairs, or groups of three with our cars...
  2. #2 Re: 02 Grand Prix won't take gas
    Dec 2016
    Fort McMurray
    Same thing happened on my 99 Trans Am. Get a thick tube of some sort and stick it in the gas tank through the filler neck. Solved it for me.
  3. #3 Re: 02 Grand Prix won't take gas
    GTP Level Member Tonkin2000GT's Avatar
    Jul 2015
    Jamestown, NY
    Happened to me get underneath the car by the filler neck and up behind the bumper or left rear quarter panel there is a big canister that vents the gas tank the mount broke on mine and the line was pinch shut caused the gas tank not to vent properly
    00 Grand Prix GT, top swapped, .020 FMP, GT1 Cam, SFI Crank pulley, SSM90, 3.3 MPS, ZZP ported Gen 3/LIM, ported heads, #90's, N* TB, SLP Intake/Headers/Catback, F-body brakes, KYB AGX, Aeroforce, AEM, 93 octane.
  4. #4 Re: 02 Grand Prix won't take gas
    Jan 2014
    AR
    If nothing is damaged, you probably just need to let more time pass between removing the cap and inserting the nozzle, particularly when fuel level is low. Open the cap, pay, then start filling. Don't open and immediately jam the nozzle in. When near empty of liquid, its full of vapor and takes a moment to vent.
  1. 2004 Grand Prix Comp GTP Rear Fenders/Quarters and Grand Prix Parts***
    By luckydogaroo in forum General Grand Prix Discussion
    Last Post: 01-30-2015, 04:00 PM
  2. Replies: 23
    Last Post: 06-21-2013, 12:52 PM
  3. Finding Grand Prix parts or Grand Prix's in Junkyards near you!
  4. 1991 grand prix 3.1 swap into 1996 grand prix 3.1
