Thread: Brown Gunk in Radiator
Results 1 to 19 of 19
  1. #1 Brown Gunk in Radiator
    SE Level Member fakir's Avatar
    Mar 2012
    Edinburg, TX
    Can anybody help me out with this. I found some brown gunk in the radiator cap and in the entrance of the radiator. Is it the Dex-cool melted?? See pics
    '04 | GP | GT2 | 162K
    Not an Expert | Just for the love of working on cars
  2. #2 Re: Brown Gunk in Radiator
    Dexcool doesn't melt, that is just what happens when old dexcool meets air. Air the coolant system over time will cause the dexcool too sludge up. Flush it out and put the new improved dexcool coolant in or switch to green coolant.
  3. #3 Re: Brown Gunk in Radiator
    thats a lot of sludge, id flush it to clear water, then add some prestone flush or the likes and drive it for a day or so, then re flush it and swap to green coolant.
  4. #4 Re: Brown Gunk in Radiator
    Sep 2015
    Cheyenne, WY
    That's gonna need a whole roll of
    Charmin to clean that up!
  5. #5 Re: Brown Gunk in Radiator
    GT Level Member mguzzo's Avatar
    Buffalo NY
    you sure you didn't just clean up after a dog?
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  6. #6 Re: Brown Gunk in Radiator
    Topeka, KS
    Dexcool sucks. That is all!
  7. #7 Re: Brown Gunk in Underwear
    GTP Level Member
    Aug 2012
    st louis park, MN
    This seriously looks like a cleanup effort after you just unloaded feces in your pants Crying of laughter at my desk because of these disturbing images.
    Dexcool is sh*tty.
    2008 Grand Prix Base: Engine cover delete , flipped dogbone bushings, Transgo shift kit, Hayden 403 trans cooler,
    Quote Originally Posted by Yarbeau View Post
    we are all anal about our vehicles. Otherwise we would not be on an extinct platforms forum debating 3000 dollars cars!
  8. #8 Re: Brown Gunk in Radiator
    Nov 2011
    NY
    Your radiator is in good shape too, including all your coolant passages... Gonna take gallons of water to flush that crap out!
  9. #9 Re: Brown Gunk in Radiator
    Dec 2012
    Where 4T65E's were born
    Our impala was worse. Flushed it thoroughly with a garden hose until no more particles or color, filled with water and 2 bottles of prestone flush. (weather above freezing obviously) A week of driving later, the water looked just as dark as the nasty coolant did. Flushed again the same way, and added antifreeze. A year and a half later the coolant is still nice and bright colored. Every so often a thin film of brown will appear in the neck, but that's it.
    Sold.
  10. #10 Re: Brown Gunk in Radiator
    GT Level Member Hpiracr28's Avatar
    Apr 2016
    Elmira, NY
    My prix has this starting to sludge up on the radiator cap. I definitely have to do a flush of the system and get the new dex cool.
  11. #11 Re: Brown Gunk in Radiator
    Topeka, KS
    F Dexcool. Put the green stuff in.
  12. #12 Re: Brown Gunk in Radiator
    Apr 2016
    Elmira, NY
    My only fear with that is not getting all the dex cool flushed out, and then having problems with the green and orange mixing.
  13. #13 Re: Brown Gunk in Radiator
    I can't car too good. SaukRapids's Avatar
    May 2016
    MN
    Quote Originally Posted by Hpiracr28 View Post
    That happened on the Blazer because I forgot the heater core like an idiot. I just ran it for like, 2 weeks and flushed it again.
  14. #14 Re: Brown Gunk in Radiator
    Topeka, KS
    Prestone makes a flush kit available on Amazon. They make a flushing solution too.
  15. #15 Re: Brown Gunk in Radiator
    Quote Originally Posted by rynoman03 View Post
    You can pick these up at pretty much any parts store, Walmart, Kmart, Target, Shopko what have you.
  16. #16 Re: Brown Gunk in Radiator
    Nov 2009
    PACNW
    Had this on my 2000 Blazer, so when I bought my 2004 Pontiac Grand Prix, I took the Dex-Cool out when new. Green coolant and 153,000 later, and I do not have the dreaded intake manifold gasket leak yet.
    I was chastised by GM technicians every time the car went in for a recall, the keys where too much weight would wear out the cylinder. Mine did not have a defective key cylinder. Now I get recall notices for the front head gasket leaking oil onto the exhaust manifold and causing fires. I refer back to my change of coolant, and how it is non issue for my car.
    Will never leave Dex-Cool in any GM product I buy. Even when new. I am sure this is part of their planed obsolescence for these engines and cars.
  17. #17 Re: Brown Gunk in Radiator
    dex coolant has been reformulated, it no longer sludge's up. i still run green, its cheaper as well. and works just fine.
  18. #18 Re: Brown Gunk in Radiator
    Mar 2017
    Burkeville TX.
    It is worth the small expense added to use distilled water, at least on your final fill. I have sworn off Dex-cool and I have gone green. Your Intake manifold gasket may be melting causing some of the gunk.
  19. #19 Re: Brown Gunk in Radiator
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Looks like you need more fiber in your diet!
    I would remove hoses, flush engine, radiator, and heater core. Add flush treatment. Follow directions, and keep doing flush treatments until clear. Drain and refill with distilled water and coolant of choice.
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  1. White/black/brownish gunk in radiator
    By Meliquin00 in forum Introductions/Noob Questions
    Last Post: 06-24-2013, 08:30 PM
  2. coolant low & gunk under radiator cap 2005 GT
    By mntnbiker in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-13-2013, 09:21 AM
  3. Brown in radiator fluid
    By Bessesen2 in forum General Grand Prix Discussion
    Last Post: 12-04-2012, 09:22 PM
  4. Brown Sludge under radiator cap
    By streetsmart in forum General Tech Discussion
    Last Post: 03-22-2009, 01:16 PM
  5. Gunk in Radiator
    By mmcfearin in forum 3.1L V6 (LHO/LG8)
    Last Post: 06-15-2008, 07:43 PM
