Thread: Fuel Pump replacement E85
Results 1 to 17 of 17
  1. #1 Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I am in the process of changing out my stock fuel pump for the AEM E85 pump. It is the stock unit and the strainer look completely clogged. 169K miles on it. Would a really cheap new sending unit with the AEM pump hold up to the E85 or should I just blow out the old strainer with some brake cleaner and air and reuse the stock sending unit??
    What would you do?
    2017 Buick Regal 2.0 Turbo (SOLD 2007 Grand Prix GT. Front and rear PLOGs, 1.8 roller rockers, CAI, HPTuned, 3.4 pulley, TEP transmission, 90# springs, rollmaster single chain, Impala front brakes d/s rotors.) Past (Pontiacs) Grand Prix- 97 GT, 03 GT, 04 GT, 04 Comp G, 78 Trans am, 92 Trans Am.
  2. #2 Re: Fuel Pump replacement E85
    id use the new sock that comes with the new pump. chances are the old one wont fit the new one.
    dont change the sending unit unless the gas gauge dont work.
  3. #3 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    There is the one that attached to the outside of the sending unit. Then the one that attaches to the new pump. The new pump comes with a new one but the sending unit one is cloggged. I cleaned the hell out of it and blew it out with compressed air so it looks better. I can't justify paying $200 plus for a new sending unit just to tear it apart to put the E85 pump in it.
  4. #4 Re: Fuel Pump replacement E85
    im pretty sure you dont know the actual names of parts in hand.
    sending unit is the rod off the side of the canister with the float, that rod moves along a board and it talks to the gas gauge in the dash board. has 100% nothing to do with the delivery of fuel.
  5. #5 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I know what the sending unit is There is an external strainer on the sending unit and the one on the actual pump itself. The new pump comes with a new pre-filter/strainer. Since I am using the old sending unit I was using the old clogged sending unit strainer/filter. That is the one that was clogged but I cleaned.
  6. #6 Re: Fuel Pump replacement E85
    as i stated, you dont know the names of the parts.
    theres only one sending unit, its the float and rod and little panel.
    the whole thing is called a canister. if you have two sock filters, im sure they both wont fit the new pump, cause its larger.
    even snowflake knows its a canister, http://www.grandprixforums.net/threa...stock-canister
  7. #7 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Sorry
  8. #8 Re: Fuel Pump replacement E85
    it just makes it hard to follow or help 100% when parts are called the wrong name. not trying to bash ya or nothing, your just confusing me
  9. #9 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I completely understand.
  10. #10 Re: Fuel Pump replacement E85
    GT Level Member brettstoner's Avatar
    Jul 2014
    Toledo, OH
    Good luck trying to find just the replacement outside sock. I looked for weeks and gave up. I personally would not reuse the stock sock if it was clogged. You can cut out the bottom of the canister and have the AEM fuel sock at the bottom of the tank (fuel slosh may cause fuel starvation). Or you can mount it inside the canister and leave the bottom open (but then you lose fuel capacity).
    04 GP GT- top swap, VS cam, 2.8 pulley, E85, headers, 60 injectors, TEP 3:29 trans, Racelogic Traction Control, ZZP dyno tuned.
  11. #11 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    Unfortunately I ended up reusing the outside strainer and now when it's running the LTFT is high which may indicate it's not getting enough fuel. Urrrgh
    I may just have to buy a new ac delco unit and use that for the E85 conversion. I have read that people use the stock pump with no issues. Any suggestions??
  12. #12 Re: Fuel Pump replacement E85
    it seems theres two types of pumps, non ventury, and ventury. it makes a difference if you use the wrong one.
    are the ltft neg or pos? pos is lean, neg is rich
    i know a guy here who was using the stock pump just fine on e85, it was not till he install a shot of NOS he started to run lean, hes since upgraded his pump.
  13. #13 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    The LTFT are positive. It is at about 12%. It did not run anywhere near that before.
  14. #14 Re: Fuel Pump replacement E85
    did you switch to e85 yet? or still on 93 ?
  15. #15 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I'm on 93 still. I wanted to be sure the pump works properly before I put in the injectors. I also need to get a tune ready in HPT.
  16. #16 Re: Fuel Pump replacement E85
    that might lead to the wrong style pump then maybe.
  17. #17 Re: Fuel Pump replacement E85
    GTP Level Member
    Jun 2016
    Cleveland ohio
    I bought the AEM E85 pump from ZZP. I'm just going to buy a new Ac Delco pump tomorrow. I'll switch over the injectors and research how to tune it while I am waiting for the pump to arrive.
  1. 04 Fuel pump replacement
    By ADrugDealer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-29-2013, 01:16 PM
  2. Best fuel pump replacement
    By JDrach in forum General Tech Discussion
    Last Post: 02-17-2013, 09:51 AM
  3. fuel pump replacement
    By rcode in forum General Tech Discussion
    Last Post: 12-09-2011, 08:39 AM
  4. Fuel Pump Replacement?
    By swoollis in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-19-2011, 06:14 AM
  5. Fuel pump replacement wtf?
    By mmschoch in forum General Tech Discussion
    Last Post: 04-21-2011, 11:41 AM
