Hi guys,
Hopefully you can guide me In the right direction, I snagged a set of offset poly square bushings from a member on here, got them installed (required cutting the factory bushings out) now the vibration is something I'm ok With, infact it seems to have gotten a little less the last few times I drove the car (breaking in a bit maybe?) But the real issue/annoyance is that the factory round bushings on the dog bones have a ton of play in them now and clank under acceleration and especially when I put the car in park and come off the brake, I verified the noise I'm hearing is coming from those round bushings by grabbing the dog bones and shaking them and sure enough they clank around something terrible. Is there any solution to this outside finding some of the round poly bushings? Seems it's the bolt and metal insert in the factory bushings has some room inside to allow them to collide, could a guy maybe wrap some electrical tape around the bolt to make a tighter fit and cushion it a bit? Or is this just too ghetto? Thanks in advance guys.
Sent from my XT1609 using Tapatalk
