Thread: Hole in engine near transmission with fiberglass coming out?
Results 1 to 13 of 13
  1. #1 Hole in engine near transmission with fiberglass coming out?
    Nov 2011
    Indiana, PA
    I don't know why I never noticed this before, but last night I noticed that my 08 GP base (v6) has a hole about 3/4" in diameter not far to the left of the transmission housing. it appears to be in the engine block and to the right of the exhaust manifold when you are standing infront of the engine bay.
    What stood out to me as odd is there is a white fibrous material coming out of it that looks like white fiberglass, I touched it and it feels soft.
    What is this? did they pack the engine somehow with fiberglass or something else near this area? Why have I never noticed this before when I cleaned the engine bay in the past? I don't remember fiberglass like material sticking out before
  2. #2 Re: Hole in engine near transmission with fiberglass coming out?
    No picture, no way for us to know what you are really talking about.
  3. #3 Re: Hole in engine near transmission with fiberglass coming out?
    HUDSON
    I know that hole. Maybe the later models have insulation in the area behind the hole to reduce NHV.
  4. #4 Re: Hole in engine near transmission with fiberglass coming out?
    Kemmerer, Wyoming
    sounds like insulation on the firewall to me
  5. #5 Re: Hole in engine near transmission with fiberglass coming out?
    Nov 2011
    Indiana, PA
    this isn't the firewall... this is the cast engine block that has this hole in it on the front side near the transmission
  6. #6 Re: Hole in engine near transmission with fiberglass coming out?
    Nov 2011
    Indiana, PA
    it's pouring rain like wild here so I'm just goanna take a net pic and show the location... circled in red is a machined hole... on mine there is a white fiberglass pack pulling out of it... it's part of the engine block, not easy to tell from this picture but it's part of the casting on my engine
    Hole in engine near transmission with fiberglass coming out? Attached Images
  7. #7 Re: Hole in engine near transmission with fiberglass coming out?
    Dec 2012
    Where 4T65E's were born
    Not sure what that port is for, but it just leads into the bell housing area, which has no fluids in it obviously. I'm guessing it was popped out and a mouse may have tried to make a nest in there? I've seen mice make lots of odd areas on cars their homes.
    Sold.
  8. #8 Re: Hole in engine near transmission with fiberglass coming out?
    GT Level Member mguzzo's Avatar
    Buffalo NY
    that is a cool T-stat housing with the fill port, though.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: Hole in engine near transmission with fiberglass coming out?
    Omaha, NE
    I always thought that hole was used to hold the flywheel from the top with something like this during production, but I have no proof of that.
    Nothing should be coming out of there. Chances are that something got pulled in from underneath and is trying to find its way out. You could always take off the starter and look up there to see if anything is trapped.
  10. #10 Re: Hole in engine near transmission with fiberglass coming out?
    Keller,TX
    Is your flywheel cover installed? If not you could have picked up something off the road and it got chewed up in the bell housing....????
  11. #11 Re: Hole in engine near transmission with fiberglass coming out?
    GTP Level Member
    Apr 2012
    Las Vegas, Nv
    Quote Originally Posted by mguzzo View Post
    Yeah. More info on that please.
    GPONA #1 Cyber Bully
  12. #12 Re: Hole in engine near transmission with fiberglass coming out?
    GT Level Member Nitvid's Avatar
    Jul 2013
    Belleville
    I had a t-stat housing similar to that on my old 94 Grand Am, 4 cyl 5 speed. you opened the radiator cap on the housing, pulled out the t-stat, installed the new one and put the cap back on.
  13. #13 Re: Hole in engine near transmission with fiberglass coming out?
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    That's a super clean engine lol all except for those rusty manifolds
    98 Grand prix SE to GTP conversion( in works). Full body conversion in works, drilled n slotted rotors, ceramics, all new suspension, custom CAI, NGK wires/Vpower plugs, SD headers, 180 Tstat, AND A WHOLE BUNCH OF PAINT BABY!! Tuned by E&J performance.
  1. Coolant coming out of transmission line bung in radiator?
    By Jim85IROC in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-07-2016, 10:33 AM
  2. Noise coming from engine
    By DustinBjug in forum General Tech Discussion
    Last Post: 04-24-2013, 10:50 AM
  3. HELP smoke coming from engine
    By SF9777 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-18-2012, 11:56 PM
  4. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  5. need ur help!!! regarding a tube coming out of the engine.
    By drewprix86 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-12-2010, 01:32 PM
