Thread: Autodim swap to compass/temp/autodim
Results 1 to 10 of 10
  1. #1 Autodim swap to compass/temp/autodim
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Is it possible to swap an onstar compass /temp Autodim to my gp that just has the Autodim? I tried Google and searching here couldn't really find a definitive answer. Thanks
    99 GTP, F1 Hood,CAI,HP TUNE,RoofRails,HID,Front/Rear STB,
  2. #2 Re: Autodim swap to compass/temp/autodim
    GTP Level Member Silver2kgtp's Avatar
    Feb 2008
    NY
    Yes you can. I did cause I needed a new auto dim mirror. I also wanted the compass. Unfortunitly I couldn't figure how to wire and get compass to work. Dimming does. LOL
    http://s1292.photobucket.com/user/si...d%20Prix%20GTP
    10.99 @ 121.99 1.74 60' (Ran out of fuel : +18 AFR)NO SPRAY!!!
  3. #3 Re: Autodim swap to compass/temp/autodim
    Sep 2015
    Seattle
    Is there an extra plug under the dome lights? I have a sunroof if that helps...
  4. #4 Re: Autodim swap to compass/temp/autodim
    Feb 2008
    NY
    The sunroof has nothing to do with the mirror.
    For some reason I'm having a brain fart and can't remember how I installed mine. Did it a whole ago. Hopefully someone can chime in
  5. #5 Re: Autodim swap to compass/temp/autodim
    Sep 2015
    Seattle
    Well I just know the overhead console is different with having a sunroof
  6. #6 Re: Autodim swap to compass/temp/autodim
    Sep 2015
    Seattle
    I just looked didn't find an extra plug..... Damn
  7. #7 Re: Autodim swap to compass/temp/autodim
    SE Level Member 1FastGP's Avatar
    May 2015
    Indian Trail, NC
    As long as you have the autodim mirror in your GP you should be able to get a onstar mirror and it's connector and just swap the pins in the connectors over. If you scroll down a little bit in this post, it covers how to do it http://www.grandprixforums.net/threa...r-view-mirrors
    Sent from my SM-G900V using Tapatalk
  8. #8 Re: Autodim swap to compass/temp/autodim
    GT Level Member mguzzo's Avatar
    Buffalo NY
    here's my post from club gp
    My 1998 had the stock Donnelly mirror with three wires: Yellow is power, Black is ground, and green is autodim inhibit. this is so the mirror will not dim when the car is in reverse. I got a Onstar mirror with a 16 pin connector and had to splice it in.
    16 pin: (*required; **required if you have a temp display)
    * 1 = Grey = not used
    * 2 = Bare = Microphone
    o OnStar Mirrors
    * 3 = = "Passenger Air Bag on" notification
    o some GM trucks - ground pin to activate icon
    * 4 = = "Passenger Air Bag off" notification
    * 5 = = auto day/night signal from LH outside mirror
    o If you have a dimmable mirror, the rearview mirror can dim it with this and pin 16
    * 6 = Brown = Temp probe connection**
    * 7 = Green/Black = Temp probe connection**
    * 8 = Black = Ground*
    o Common to Pin 9
    * 9 = Light Green = Reverse Dim Inhibit
    o Common to Pin 8, +12V from reverse lights to disable dimming
    * 10 = Gray = Microphone
    o OnStar
    * 11 = Dark Green/White = keypad signal (out)
    o OnStar - multiplexed signal
    * 12 = Light Green = keypad +5v supply (in)
    o OnStar
    * 13 = Yellow = +12V switched (ignition)*
    * 14 = Yellow/Black = Green LED signal
    o OnStar - apply 12v to light LED.
    * 15 = Brown/White = Red LED signal
    * 16 = = day/night signal to LH outside mirror
    o If you have a dimmable mirror, the rearview mirror can dim it with this and pin 5
    So I took to old mirror off and took down the sunroof switch bezel to access the wiring. Snipped the mirror wires (no connector) and pulled the mirror out. I installed the new mirror, it fit the shoe fine but I had to find a #8 machine screw to lock it into place. Ran the wires up into the headliner and spliced in
    Car yellow -> pin 13 power
    Car black -> pin 8 ground
    Car green -> pin 9 inhibit
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: Autodim swap to compass/temp/autodim
    Feb 2008
    NY
    good info thanks.
  10. #10 Re: Autodim swap to compass/temp/autodim
    GT Level Member 0069GTP's Avatar
    Oct 2014
    Western NC
    Quote Originally Posted by 1FastGP View Post
    The link above has great info on the mirrors. I have switched all mine out to the newer Gentex models with temp and compass (7 pin connectors). These mirrors can be found in other cars as well, it doesn't have to come from a GP, just go to a local salvage yard and look around. Just make sure to to get the connector with it and swap the terminals as shown. I personally wouldn't go with an Onstar mirror, no need to have a bulkier mirror with useless button on it.
  1. Replace autodim mirror with normal non dimming mirror?
    By mainecrab in forum General Tech Discussion
    Last Post: 03-05-2015, 08:31 AM
  2. 04+ BLUE DIC swap w/ bezel, compass module, temp sensor
    By jcihos in forum For Sale - Parts
    Last Post: 07-21-2014, 09:36 PM
  3. WTB driver's side tail light assembly and autodim rearview mirror
    By buickman104 in forum Wanted To Buy - Parts
    Last Post: 05-05-2014, 10:23 PM
  4. Add an autodim!
    By Crysalis010 in forum Audio, Security & Visual Electronics
    Last Post: 03-29-2011, 01:20 PM
