Thread: Battery draining from subs?
Results 1 to 3 of 3
  1. #1 Battery draining from subs?
    GT Level Member Brammer's Avatar
    Feb 2009
    Roanoke, VA
    So here's the gist of it so far. I bought the car last year, transferred my sub setup and head unit into it and used a Rockford Fosgate wiring kit for the whole process. Last week I noticed that out of the blue (just the one time) I could hear the subs buzz with input when I did the lock/unlock on my keyless entry. Yesterday morning I went to take the care to work and it's dead, no juice whatsoever. It's a 2002 Grand Prix GTP, battery was just replaced about 5 months ago with a brand new one.
    After work I went to jump it and the car initially got enough juice that I could open the doors using my keyless, and the subs did make that buzz again, but after picking up the sub power lead fuse block under the hood and moving it around to check it it's like it the car lost any power flowing from the jumping vehicle and was back to 100% dead. So then it acts like it's not getting anything power-wise from the jumping vehicle, it's like there's a short somewhere down the line that's just letting the juice flow through the power lead to the subs and grounding out.
    I removed the power lead for the subs from battery and hooked the jumper cables back up and immediately it's got power flowing to the car again. So I jumped it, let it run, took it around everything is good. Shut it off, reconnected the sub power lead, no more buzzing through the subs at keyless use and the car fires up no problem again. I did note that the first time putting the power lead back on it sparked, I removed it to test and then put it back on, putting it back on a second and third time, no spark.
    However this morning, 100% dead again. Ideas as to where my short could be? I checked the wiring on the back of the sub box and all the wiring is where it should be and connected properly. The ground for the amp is the same gauge as the power lead and it's connected from the amp to one of the bolts on the underside of the trunk deck as it's always been. I've also noticed my gas gauge recently has been hunting around instead of reading properly, possibly a symptom or just coincidence?
  2. #2 Re: Battery draining from subs?
    SE Level Member jaydubb71's Avatar
    Apr 2013
    Waldorf MD
    Are you running a capacitor inline with the sub power wire? Is your amp turning off? What brand of amp?
    I would disconnect the capacitor (if you have one) and see what happens. If the sub power wire was shorted, it would pop the inline fuse (Im praying that you have a fuse inline... LOL).
    1998 GTP Coupe: Self-tuned with HPTuners, 3.4, FWI w/ 12 inch K&N, Autolite 103's, hot-wired FP, Caspers fan override, 180 t-stat, Speed Daddy headers, SLP exhaust w/ GTX tips, 12 inch brakes (Riviera/Impala), 6000K HID's, solid rubber engine and trans mounts, poly dogbone inserts (SOLD 3/2020!!! )
  3. #3 Re: Battery draining from subs?
    Feb 2009
    Roanoke, VA
    Nope, no inline cap. It's an Alppine MRP M450 mono block connected to two Alpine 12" Type E Subs. Yeah, haha there's a nice big old fuse block under the hood on the main power lead for the sub. Ah sorry it's not Rockford, it's a Kicker setup. Here's the exact one. Yeah, the amp is turning off like it's supposed to, so I assume the remote wire is still connected on the wiring harness for the head unit haha.
  1. Battery draining / Alternator or ??? Please help
    By BlueZRX1200R in forum General Tech Discussion
    Last Post: 04-08-2016, 10:27 AM
  2. Battery draining
    By izup69 in forum General Tech Discussion
    Last Post: 02-12-2013, 07:06 PM
  3. 2004 Pontiac Grand Prix Battery draining while car is off Please help someone!!!!!
    By postal G in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-24-2013, 05:57 PM
  4. draining coolent
    By fremmy182 in forum General Tech Discussion
    Last Post: 10-10-2010, 12:48 PM
  5. 2000 Grand Prix Gt draining battery
    By Kranium31 in forum General Tech Discussion
    Last Post: 01-22-2010, 07:42 PM
