Thread: Think something chewed my wiring.
Results 1 to 20 of 20
  1. #1 Think something chewed my wiring.
    GT Level Member firstdue's Avatar
    Toledo, Ohio
    Ok, drove the car to work yesterday and it ran flawlessly. Started it up this morning and it sounds like it has a "miss". Drove it home and it was really sluggish and didn't idle smooth.
    Opened the hood to find a plug wire in 2 pieces shorting out. Also found another harness with wires that appear to be chewed through.
    2 questions:
    What brand plug wires do you guys recommend?
    Can anyone identify what these wires go to?
    Thanks!
    2009.1 Liquid Red G8 GT
    2001 Grand Prix GT Bright Red
  2. #2 Re: Think something chewed my wiring.
    Toledo, Ohio
    #6 wire
  3. #3 Re: Think something chewed my wiring.
    any parts store plug wire set works fine.
    looks like the o2 pig tail. open up the loom, patch up your wires.
    you're # 3 on wires being chewed on this week.
  4. #4 Re: Think something chewed my wiring.
    Toledo, Ohio
    Thanks! Looked closer at that harness and I should be able to patch the few wires in it.
  5. #5 Re: Think something chewed my wiring.
    GTP Level Member
    Jun 2016
    Cleveland ohio
    yep, critters love to sleep under that engine cover. I've had to repair several peoples wiring harnesses because of this issue. I did one persons and the critter chewed through another part a couple weeks later.
    AC Delco OE wires are about as good as you can get. I also like Autolite.
  6. #6 Re: Think something chewed my wiring.
    Toledo, Ohio
    Of course the rodent had to chew threw the #6 wire. Struggled with getting the wire off the plug until i made my own make shift tool from a coat hanger than resembles this:
    https://www.amazon.com/Lisle-51250-S.../dp/B0002STS4E
    New wire is on and car runs much smoother on 6 cylinders than 5...haha.
    Now I have to splice the 4 wires leading to what i think is the o2 sensor.
    Couple questions?
    Will it hurt the run the car with those wires disconnected? I currently have a "SES" light which i am assuming is due to the wiring.
    Whats the best way to splice the wires? Solder? They were chewed in a few places so I'm definitely going to need to add wiring.
    THANKS!!
  7. #7 Re: Think something chewed my wiring.
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by firstdue View Post
    If the car runs, go for it. I'd at least make sure no bare wires are exposed that could ground or short out.
    Solder them together then cover with shrink-tube. A little di-electric grease will also help keep moisture out if you are in a wet climate.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: Think something chewed my wiring.
    Feb 2013
    37.295091, -121.930053
    i once had a mouse in my engine bay but that didnt last to long once i started the car up he went running towards the belt then got flung up with a broken neck then hit the garage door you know the old wooden ones that weigh a ton yeah that one. He hit his head on the door and cracked his head will say this tho he was dead dead lol
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  9. #9 Re: Think something chewed my wiring.
    Toledo, Ohio
    I was hoping he was chewing on the plug wire when i fired the car up...lol
  10. #10 Re: Think something chewed my wiring.
    Jul 2010
    Coquitlam,BC,Canada
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  11. #11 Re: Think something chewed my wiring.
    The way I see it.. a 2001 with original wires. It was overdue.
  12. #12 Re: Think something chewed my wiring.
    Toledo, Ohio
    Ok, everything is back together and I have a SES light now. I did not have it the first day i drove the car minus one plug wire. I did notice it on the 1st start up with the new plug wire but before the o2 sensor harness repair.
    While I did the o2 sensor harness repair i disconnected the battery. Car appears and feels to be running as it should with the exception of the SES.
    Autozone pulled these codes:
    P0102 MAF Sensor Circuit Low Freqency
    P0141 HO2S-12 Bank 1 Sensor 2 Heater Circuit Malfunction
    P0443 EVAP Solenoid No 1 Control Circuit Malfunction
    P0135 HO2S-11 Bank 1 Sensor 1 Heather Circuit Malfunction
    Any suggestions?
    As always Thank you! for all of the assistance!
  13. #13 Re: Think something chewed my wiring.
    Jul 2010
    Coquitlam,BC,Canada
    I had a MAF code years ago when I had things apart. Wiggled and re-plugged in the MAF and never saw it again.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  14. #14 Re: Think something chewed my wiring.
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    double check the rest of the wiring, might be more that the damn thing chewed through.
    My horn still doesn't work. lol
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  15. #15 Re: Think something chewed my wiring.
    Toledo, Ohio
    Thanks guys! Looked everything over and it all looks intact. Only area I can't really see well is down below behind the engine.
  16. #16 Re: Think something chewed my wiring.
    Toledo, Ohio
    Just found my #21 fuse blown under the hood.
  17. #17 Re: Think something chewed my wiring.
    Toledo, Ohio
    Woohoo! Fuse replaced and no codes!!
  18. #18 Re: Think something chewed my wiring.
    Jul 2010
    Coquitlam,BC,Canada
    Nice!
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  19. #19 Re: Think something chewed my wiring.
    Toledo, Ohio
    Thanks again!! For the suggestions!!
  20. #20 Re: Think something chewed my wiring.
    i was gonna say the fuse blew for sure being it was chewed through. ING blown again lol
  1. Replies: 4
    Last Post: 04-29-2015, 07:03 AM
  2. wiring help
    By DDPeppa in forum Audio, Security & Visual Electronics
    Last Post: 12-10-2010, 11:19 PM
  3. Help with LED Wiring?
    By FastKatt in forum Audio, Security & Visual Electronics
    Last Post: 01-22-2009, 10:28 PM
  4. Potholes; chewed up roads everywhere!
    By jagamite in forum The Rant Forum
    Last Post: 01-20-2009, 10:39 PM
  5. Amp Wiring
    By JayAz in forum Audio, Security & Visual Electronics
    Last Post: 11-23-2008, 11:43 AM
