Thread: Header install vibrations
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Header install vibrations
    GT Level Member willie14's Avatar
    Jun 2016
    westland mi
    Have u tried a different gap on your sparkplugs? That seems like u pulled a ton of timing out to keep it down.
  2. #22 Re: Header install vibrations
    Jun 2016
    westland mi
    I'd hate to have to jump back up a pulley size because I couldn't get the tune right with a smaller pulley, but I guess that's where the tuner pros gonna come in for me as this I gonna be my first 3800 build
  3. #23 Re: Header install vibrations
    Nov 2011
    NY
    Bigger pulley doesn't always equate to more HP... Smaller pulley no knock ++timing = ++HP
  4. #24 Re: Header install vibrations
    lets just say, your not running a smaller pulley with out more flow mods, or a ic, or e85.
    i got ported heads, 1.95 rockers, a fsic ported lim, and 42 lb injectors. it wont take much timing at 10 psi. but at 7 psi it will take 18 degrees wot.
    your best to buy a tuner, canned tunes dont always work so well for a top swap. they need tweaking to get right, then you can play the boost vs timing game. no tuner,,,,you'll never know what its capable of.
  5. #25 Re: Header install vibrations
    Jun 2016
    westland mi
    I gotta buddy of mine who does it for a living who's going to tune my car as I modify it. Right now he's tuning a g8 so I'm pretty anxious to see what that and my car is capable of
  6. #26 Re: Header install vibrations
    before the ic, i had a 3.4 on there, it was getting 6ยบ kr at part throttle with stock l67 timing. so i put the stock pulley on and then ran one degree less wot timing and it had no kr at that point.
  7. #27 Re: Header install vibrations
    Jun 2016
    westland mi
    But your losing engine performance by having to go back to that stock pulley tho right?
  8. #28 Re: Header install vibrations
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Still more compression then a l67.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  9. #29 Re: Header install vibrations
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    with an N/A bottom end, an otherwise stock L67 or L32 will make ~5 more HP than a bone stock s/c engine, but KR is a much bigger issue and a top/bottom swap needs to have flow mods in order to be safe.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  10. #30 Re: Header install vibrations
    Jun 2016
    westland mi
    I forgot he's got a L36 bottom end
  1. header install ?'s
    By taman86 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2011, 12:16 AM
  2. Header Install
    By chrisgsx in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2010, 05:22 PM
  3. SD Header Install Soon...
    By theshznt69 in forum 04+ Specifics
    Last Post: 05-23-2010, 05:28 PM
  4. ZZP Header Install
    By Xorbex in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-12-2010, 09:08 PM
  5. my header install needs help
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-09-2009, 04:57 PM
