Thread: Lifter noise
Results 1 to 12 of 12
  1. #1 Lifter noise
    GT Level Member Hpiracr28's Avatar
    Apr 2016
    Elmira, NY
    I had a 98 old cutlass with the 3.1 which had some lifter noise. My dad's 06 grand prix 3.8 has some lifter noise under hard acceleration. I believe my 03 grand prix 3.1 has some lifter noise on startup as well. If this is what is making the knocking, is there any oil additive to solve the knock? Motor honey? Lucas oil additive?
  2. #2 Re: Lifter noise
    You can try some oil additive to clean the lifters or use transmission fluid, either will work.
    It's hard to say if that will do the trick though, some motor will just always be noisy untill you replace them. GM lifter clatter is very common and most cars will run just fine with it.
  3. #3 Re: Lifter noise
    Apr 2016
    Maryland
    I have read a lot about this noise your speaking of. Most cars will make this sound their whole life. It's not damaging anything. I replaced the lifters on my friends car and the noise was gone, but it only lasted a few months. I know it's annoying and people think your car is running like ****, but it's really not worth the work cause the noise will come back.
  4. #4 Re: Lifter noise
    Apr 2016
    Maryland
    Ffdp ,using transmission fluid doesn't sound like a good idea
  5. #5 Re: Lifter noise
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    I'm going the same route as ffdp. I would replace a quart of oil with trans fluid...run it a few hundred miles, change the oil.
  6. #6 Re: Lifter noise
    Apr 2016
    Maryland
    What does the Trans fluid clean out the gunk? And won't the Trans fluid swell up any seals it touches?
  7. #7 Re: Lifter noise
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Get new lifters quick and easy.
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  8. #8 Re: Lifter noise
    Transmission fluid has cleaners that regular oil does not, some of those cleaner are in some the highest end oils now like amsoil or better. Some people say it does nothing but many of those people have not tried it and follow what other people say about it not working.
    I've done it many times over will good results, it does not harm anything while doing this. Trans fluid is the super cheap way to try and clean out a motor by cutting down the sludge.
  9. #9 Re: Lifter noise
    Apr 2016
    Maryland
    Okay cool. Think I'll try that also. Thanks for the info ffdp
  10. #10 Re: Lifter noise
    Apr 2016
    Elmira, NY
    It's not a constant knock, and very faint at this point. Thanks for the pointers though. When it gets bad enough, I'll try the mentioned remedies. I'd prefer not to tear apart the top half and replace lifters. Did that on my olds along with other major engine repairs... accidentally swapped intake and exhaust push rod...bad news lol
  11. #11 Re: Lifter noise
    Apr 2015
    My wife's 2000 GP w/ the 3.1 has had lifter noise for thousands of miles. It's most noticeable on a cold start.
    Sent from my LGL41C using Tapatalk
  12. #12 Re: Lifter noise
    Nov 2011
    NY
    3100 60* GM engine is known for lifter tick cold... My old GP with 3100 that my son drives now has 270k and lifter tick for 240k, lol
  1. Lifter noise
    By jonyaniro in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-27-2012, 08:32 AM
  2. Possible lifter noise, not sure. Please help me out! Video inside
    By thatguy in forum General Tech Discussion
    Last Post: 10-26-2012, 05:18 PM
  3. Lifter/ticking noise???
    By kind153 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-24-2010, 12:43 PM
  4. loud lifter noise any ideas?
    By breeze12 in forum Introductions/Noob Questions
    Last Post: 06-05-2009, 02:12 PM
  5. Ticking noise, thinking lifter
    By bradford82 in forum General Tech Discussion
    Last Post: 01-25-2009, 10:44 AM
