Thread: Oil life on dic
Results 1 to 13 of 13
  1. #1 Oil life on dic
    GT Level Member Jnibbs24's Avatar
    Sep 2015
    Seattle
    Does anyone even trust the oil life % or know how accurate it is? I always use mobil 1 synthetic I have about 2800 miles before my next oil change but the dic says I have 7% oil life.
    Thanks
  2. #2 Re: Oil life on dic
    Kemmerer, Wyoming
    One of the problems is the factory recommended oil change interval is often different than what people actually follow. I have a 2014 Chevy Cruze, and the oil change interval recommended by the factory is every 7500 miles. that is a lot of miles between oil changes, and I change the oil more often than that. I'm not sure what the dic is programmed to calculate, but I try to reset it every time I change the oil, and it usually drops down to 40 or 50% before then next change.
  3. #3 Re: Oil life on dic
    Sep 2015
    Seattle
    Yeah my gf has a newer forte and they said the same, I was like uhhhhh I'd change it before that. I still think I might change it before the 5k mile recommend on mobil 1. Just sems weird.
  4. #4 Re: Oil life on dic
    Feb 2013
    37.295091, -121.930053
    on my gp when i got it the "oil life" was at 50% when i changed it the oil looked really black for just 50% i would go by how many miles i put on it the DIC cant be trusted its great for know when someone has a door open but even then it takes what 2 seconds to look?? so really if its been more than 3000 miles then yeah change it
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Oil life on dic
    Engine run time and and the type of driving you do will determine how quickly it goes down.
    If you idle it alot warming it up and drive mainly city, it will go down faster. But if you only drove freeway, you'd hit the 3,000-5,000 miles before it ever reached zero.
  6. #6 Re: Oil life on dic
    Jul 2010
    Coquitlam,BC,Canada
    I find the oil change sticker on my windshield is far more accurate. I change my oil on a regular basis (5-6000km), but the DIC advises me to soon or to late, so I just reset it when it lights up.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  7. #7 Re: Oil life on dic
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Lol I was just wondering about this. According to the dic I got 26.7mpg on my trip back home cruise set at 80. 376 mile trip and it said I still had another 70 I could go.
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  8. #8 Re: Oil life on dic
    Quote Originally Posted by Travisgt2 View Post
    Well that's a slightly different topic but your computer was pretty accurate though. 26.7 mpg with 17 gallons is 454 miles, so you could have gone another 70 miles but at the risk of running out.
  9. #9 Re: Oil life on dic
    Jan 2013
    leavenworth ks
    This is my first time driving with my five button dic and first trip with it. I love being able see my trans temp and volts. As for oil life I don't trust it I change mine every 3k no matter what some times little before if I know I have a trip coming up. I also run 8oz Lucas heavy duty stop leak every oil change. Oil has been looking a lot better when I change it and Oil pan leak has slowed a little
  10. #10 Re: Oil life on dic
    Jan 2014
    AR
    I like to keep an eye on the oil's clarity and base my interval on that, but- I've put around 80K miles on my 99 GPs, and from that experience I can say this...
    0% oil life takes more like 7,500 miles. If you change your oil at about 35-40% by the DIC, you are right in that 2500-3000 miles range where most car guys will want fresh oil with new filter. As far as the DIC MPG goes, subtract 1.5-2 MPG and its fairly realistic. Lots of variables in play on both subjects.
  11. #11 Re: Oil life on dic
    SWPA
    I was just talking about oil life monitors at work today. I wouldn't trust them for a second. They are based on calculations and equations and not real world mileage.
    Hell I remote start my car and because it's remote started things like the oil life monitor, estimated mpg, etc don't calculate at that time so it's wrong from the start.
    When I used to drive 24 miles to work with half of it being a 4 lane road I wouldn't even be at 50% after 5,000 miles, so if I was stupid and followed the DIC then I wouldn't have changed the oil til well after 10,000 miles.
    I buy cheap non synthetic oil (whatever is on sale) and a Purolator filter and change the oil every 5,000 miles (or 6 months when I was hardly putting any mileage on it) and the car is just shy of 185k miles. I bought it with 123k 5 years ago. If I trusted the oil life monitor I would guess my engine wouldn't have lasted this long.
  12. #12 Re: Oil life on dic
    Nov 2012
    Madison
    Just did mine last week...dic said 46% with 4875 miles on it....mostly 50-75mph driving.
    The oil wasn't completely nasty black either.
  13. #13 Re: Oil life on dic
    GTP Level Member buickman104's Avatar
    NYC
    The DIC calculated based on idle time and a bunch of other factors. I drive about 4 hours a day in New York City traffic and after about 1,000 miles my oil life is at 20-30%. Before I worked this job I would change the oil about 2-4 times a year based on the DIC. So I would follow it. Oil changes are cheap and easy.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  1. Life after a GTP
    By rvnwlf in forum General Grand Prix Discussion
    Last Post: 07-29-2015, 11:03 AM
  2. Oil life
    By Boilermaker894 in forum General Grand Prix Discussion
    Last Post: 03-20-2014, 07:58 PM
  3. oil life
    By tegbir in forum General Tech Discussion
    Last Post: 09-10-2012, 08:43 PM
  4. Oil Life
    By mlasnoski in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-30-2010, 07:32 AM
  5. oil life?
    By banzai7 in forum General Tech Discussion
    Last Post: 07-11-2009, 12:40 AM
