Thread: Fuel pump canister wiring question
Results 1 to 4 of 4
  1. #1 Fuel pump canister wiring question
    SE Level Member buford1972's Avatar
    Apr 2009
    Peoria, Arizona
    This may have been answered previously but I haven't been able to find it...... please go easy on me :-) There isn't anything wrong with my current (stock) fuel pump but just out of preventive maintenance due to 120K miles on the odometer I am going to replace it on my 2000 GTP project with a Racetronix unit. I pulled out my canister to see just what I had and I noticed a black plastic box that is snapped between two of the three spring rods at the bottom just above the fuel pump. The power leads for the fuel pump go from the bulkhead connector, into this box, and then back out before connecting to the pump itself. I probed it with an Ohm meter thinking it was some sort of resistor (which doesn't make any sense because it is located inside the fuel tank). My next guess is that it was some sort of elaborate way to hold the wiring stationary which seemed ridiculous as well. Does anyone have any actual knowledge of what this thing is for?
    Comp Cams Cam. #150 springs. roller rockers. CNC heads. 3.4" pulley. P&P Gen V. 8-rib w/belt wrap. N* & LQ4. 1" phenolic spacer. P&P/coated LIM. boost temp gauge. Aeromotive fuel rails. underdrive W/P pulley. coated TOG headers. Magnaflow cat back. Random Tech DP & Cat. balance shaft delete. built trans. Hughes converter.
  2. #2 Re: Fuel pump canister wiring question
    Mar 2014
    Tucson
    Can you post a pic?
    Here's what mine looked like when I had the racetronix pump:
  3. #3 Re: Fuel pump canister wiring question
    Apr 2009
    Peoria, Arizona
    Ok, I figured out the answer to my question. The rectangular black box that is inline with the fuel pump power wires that are inside the canister are an EMI/RFI filter. I just received a replacement fuel level sensor and wiring for my car that does not have this EMI/RFI filter inline on the wiring. Is there anyone who has omitted this EMI/RFI filter with the stock pump and had any ill effects with radio static or noise? I am not using the stock radio so this may be the deciding factor.
  4. #4 Re: Fuel pump canister wiring question
    hangover park IL
    it'd be more likely to hear it with a ground loop issue, you shouldn't have a problem. I drill a hole and run straight 10ga wire with an rtv plug bypassing the massive voltage drop of the oem connections.
    ~James~ Psychotic Gearhead
  1. ISO Venturi style fuel pump canister.
    By JDrach in forum Wanted To Buy - Parts
    Last Post: 08-20-2014, 06:13 PM
  2. venturi fuel pump canister
    By Maximum Gnarnage in forum Wanted To Buy - Parts
    Last Post: 03-23-2013, 06:22 PM
  3. Son of a... installing fuel pump canister. Need help!
    By Agentlongwood in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-06-2012, 01:33 AM
  4. Racetronix Fuel pump canister install questions...
    By Iron Indian in forum General Tech Discussion
    Last Post: 05-18-2009, 12:11 AM
