Thread: fuel pump problems
Results 1 to 11 of 11
  1. #1 fuel pump problems
    Feb 2016
    Marathon
    I have a 04 grand prix gtp comp g and it was low on gas b/c i was putting it up for the winnter and i thought it ran out of gas but now i have a 1/4 tank and the fuel pump is not kicking on. The battery also was not charged from sitting. Can anyone help me out fuel pumps are expensive and i do not want to buy one unless thats what it is.
  2. #2 Re: fuel pump problems
    May 2012
    Where winter never ends
    Check the fuses and relays under the hood. Pop off the access port in the trunk (under the carpet toward the front of the car) and see if you can hear it priming. Should sound like a whine.
    2000 Regal - Winter Beater
  3. #3 Re: fuel pump problems
    turn key to run, then see if you have fuel pressure at the rail via the shrader valve.
  4. #4 Re: fuel pump problems
    Feb 2016
    Marathon
    I have checked the fuses already and also have the have the access cover off to and am getting power the plug on the pump and its not making any noise and also there is no pressure on the fuel rail. Ik how to work on older cars its just all this new junk that u have to be a nerd to figure out lol Is there something that would make the pump its self not work at all ?
  5. #5 Re: fuel pump problems
    GXP Level Member
    Mar 2015
    Tomball
    Come on now, electric fuel pumps have been on cars since the 80's. What voltage did you see at the plug? The fuel level sensor is in there too.
  6. #6 Re: fuel pump problems
    you need a new pump. you figured it out already.
    you can buy just the pump for 50 or less off ebay, or up to 300 for a whole canister and pump at a local parts store. local stores dont sell just the pump any more it seems.
  7. #7 Re: fuel pump problems
    Feb 2016
    Marathon
    I do have to say thats funny but i was reading a bunch of **** looking for like a safety shut of switch and people say to do all sorts of things but is there a difference in psi if i was just to buy the pump off ebay and not the whole unit. i do not have a voltage gauge just a test light.
  8. #8 Re: fuel pump problems
    if you got power to the pump, and cant hear or feel it run, and have no pressure at the rail,,,,,,its painfully clear the pump took a crap.
    a pump for your year car is the pump for your car. the pressure will be fine once you got a new one installed.
  9. #9 Re: fuel pump problems
    Feb 2013
    37.295091, -121.930053
    dont forget the fuel filter when you change the fuel pump.
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  10. #10 Re: fuel pump problems
    St. Louis
    If you need to move it for some reason, climb under the car and find the center of the tank as you may be able to coax it back to life one more time by gently smacking the tank with a rubber mallet. Have someone turn the key to ON and smack the tank and see if it runs. I've done this before in order to move a car with a bad pump, but don't count on it to work again if you shut it off.
  11. #11 Re: fuel pump problems
    Feb 2016
    Marathon
  1. 04/05 fuel pump install- Fuel pump access in trunk
    By chrsmi1 in forum How To Write-Ups/Tech Tips
    Last Post: 04-18-2015, 09:26 PM
  2. Fuel Pump Relay Problems
    By NIKGTP98 in forum General Grand Prix Discussion
    Last Post: 06-24-2012, 12:41 PM
  3. 2000 GTP fuel pump relay problems
    By torqueaddict in forum General Tech Discussion
    Last Post: 06-11-2011, 07:14 PM
  4. Fuel pump problems
    By Joe in forum General Tech Discussion
    Last Post: 01-15-2011, 12:04 PM
  5. Fuel pump problems?
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 07-10-2010, 11:43 AM
