Thread: Parking lights staying on and stuttering when starting.
Results 1 to 6 of 6
  1. #1 Parking lights staying on and stuttering when starting.
    Aug 2015
    Virginia
    My parking have recently started staying on after I park the car and get out, had to pull the fuse to get them to turn off. I also have started to experience some stuttering when starting my car. 2005 Grand Prix GT
  2. #2 Re: Parking lights staying on and stuttering when starting.
    St. Louis
    Remove and clean both battery terminals. Corroded/loose terminals cause weird things sometimes.
    As far as the starting issue I'd remove the entire throttle body and clean it inside/out. They get carboned up on the backside of the butterfly valve and cause issues. Clean the MAF with approved MAF cleaner and see what you get.
  3. #3 Re: Parking lights staying on and stuttering when starting.
    SWPA
    It sounds odd, but when the battery was weak on my key FOB it made the parking lights stay on unless I double hit the lock button.
  4. #4 Re: Parking lights staying on and stuttering when starting.
    Aug 2015
    Virginia
    I've checked into that but I have the Dorman remote and even with a new battery I get a low battery alert so they're sending me a new one
  5. #5 Re: Parking lights staying on and stuttering when starting.
    SWPA
    The low battery alert is why the lights are staying on. Just make sure you double hit the lock button and they should go out.
  6. #6 Re: Parking lights staying on and stuttering when starting.
    Aug 2015
    Virginia
    Alright, thank you
  1. Why might my cabin lights be staying on all of a sudden?
    By Centauri in forum General Grand Prix Discussion
    Last Post: 03-11-2015, 02:45 AM
  2. Replies: 3
    Last Post: 01-16-2010, 07:19 PM
  3. no parking lights
    By jsun in forum General Tech Discussion
    Last Post: 10-05-2009, 01:13 PM
  4. Just parking lights?
    By Deezul_AwT in forum Visual/Body Modifications
    Last Post: 09-01-2008, 01:24 PM
