Thread: belt wrap
Results 1 to 17 of 17
  1. #1 belt wrap
    GTP Level Member Dee23's Avatar
    Jul 2012
    North Philly
    At what pulley size is a belt wrap needed to prevent belt slip?
    Not your average grocery getter, but theres always at least two things on the list.... 10w-30 Castrol Titanium and Shell 91 premium mixed with a lil 100 octane racing gas......
  2. #2 Re: belt wrap
    May 2008
    Schuyler, NE
    Depends on a few things, but usually it's in the sub 2.8 range.
  3. #3 Re: belt wrap
    Jul 2012
    North Philly
    What are those few things? Im gonna be running a 2.8" pulley
  4. #4 Re: belt wrap
    hangover park IL
    you'll know when you start to get into it you'll find the black powdered rubber dust
    ~James~ Psychotic Gearhead
  5. #5 Re: belt wrap
    If you're not 2.6" or lower, I wouldn't really see any point honestly.
  6. #6 Re: belt wrap
    Kemmerer, Wyoming
    I had no belt slip on my 2.8" pulley car. if you have a tuner you should be able to see changes in boost if the belt is slipping or fluctuations in map and air flow where there shouldn't be any fluctuation.
  7. #7 Re: belt wrap
    Jul 2012
    North Philly
    Yeah what ill probably do is just get ZZPs oversized tensioner pulley
  8. #8 Re: belt wrap
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Thought this thread said "belt warp" at first, and was like, what?
  9. #9 Re: belt wrap
    hangover park IL
    Quote Originally Posted by Dee23 View Post
    the G/H body bracket is a good increase in belt wrap, but both it and the iron W body bracket can be imprived by using the 3.5" pulley on the tensioner and using the dodge/mercedes/etc 2.5" dia ribbed pulley....you can gain a couple more degree's of belt wrap.
    ron vogel also proved that if you had slip you could roll a triangle file through your polished sc pulley grooves to creat teeth to add traction if you think your starting to slip
  10. #10 Re: belt wrap
    Jul 2012
    North Philly
    At first i was thinking wbody belt wrap than i remembered ZZPs oversized tensioner pulley plus its cheaper
  11. #11 Re: belt wrap
    Buffalo
    I have this one but I've decided not to use it ... Yet. I'm a 2.8 with the 8 rib conversion. No slip.
    maybe ill try it out if I toss the 2.6 on or else I'll just sell it
    (Loose test fit for mock up )
  12. #12 Re: belt wrap
    Jul 2012
    North Philly
    That block looks good, you power coated the block red?
  13. #13 Re: belt wrap
    It's engine enamel
    04 Comp G.
  14. #14 Re: belt wrap
    Jul 2012
    North Philly
    Looks good, i need a damn engine stand
  15. #15 Re: belt wrap
    Buffalo
    Thanks. There is more pics in the link in my signiture.
  16. #16 Re: belt wrap
    Jul 2012
    North Philly
    Great 3800 build!!!
  17. #17 Re: belt wrap
    Jul 2012
    North Philly
    Are u selling that belt wrap pulley?
  1. Who here has a belt wrap kit from wbodystoere?
    By Hardonyomom in forum General Tech Discussion
    Last Post: 12-21-2014, 06:45 PM
  2. Go 8 rib or get a belt wrap?
    By crbquist in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-31-2013, 10:49 AM
  3. PC Belt Wrap Kit finally on the car....
    By Iron Indian in forum Off Topic Discussion
    Last Post: 10-20-2008, 10:11 PM
  4. SS M-90 belt wrap solution!!
    By chico in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 09:38 PM
