Thread: 04 Indy no start
Results 1 to 3 of 3
  1. #1 04 Indy no start
    Dec 2014
    United States
    Hey guys it's been a while. NO CODES BTW. I have a no start issue where my car cranks but will not start. All I did was replaced the old wires with Delco PN#946BB and Delco 41-101 plugs. Now she won't crank. I have replaced the ICM, TPS, MAF, CKP, IAC sensors, and fuel filter. I have fire at the coil packs but none in the combustion chamber. The plugs are just soaked with gas. Fuel pressure reads 45 psi. My injectors read 11.9 volts. My coils read 5k ohms. And I'm at a lost. How can it go from working with minor misfires to not running at all. I have DashCommand and a wifi scanner the numbers are all where they should be. 111 RPMS on 3k, 12.94 volts on the battery, and -0.4 on TPS. I gave cleaned and checked the ground for the icm and all. I cleaned the PCM connectors and the bracket that the ICM mounts to. Anyone ever run into this problem or have any idea of what to do?
  2. #2 Re: 04 Indy no start
    Dumb question, did you route the wires correctly?
    Front is 1,3,5 and rear is 2,4,6.
  3. #3 Re: 04 Indy no start
    Dec 2014
    United States
    Yea I have them right. I got spark at the towers but not the plugs. It's weird because I literally had i problems. I put the car in a covered garage due to a rainstorm, it had gotten really cold here. Next day no dice. I've tried everything. What are the odds of a whole new wire set being bad? Could a coolat temp sensor cause this? Everything else has been changed.
  1. HELLO I AM NEW FROM INDY AND I Need Some Help...
    By Jays24 in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 08:14 AM
  2. New in Indy with GP #4
    By SteelBiker in forum Introductions/Noob Questions
    Last Post: 12-09-2011, 08:15 PM
  3. Hello from Indy!
    By lilwillgp in forum Introductions/Noob Questions
    Last Post: 09-18-2010, 09:00 PM
  4. Hi From Indy
    By hannon in forum Introductions/Noob Questions
    Last Post: 06-03-2010, 11:36 PM
  5. New from Indy
    By bct717 in forum Introductions/Noob Questions
    Last Post: 03-14-2009, 11:50 AM
