Thread: Door Won't Open
Results 1 to 12 of 12
  1. #1 Door Won't Open
    Jul 2015
    Kalamazoo, Michigan
    Hello, everybody!
    I recently bought an 02 GTP for myself and I love the car. One of the problems I'm having and trying to fix, however, is the rear driver's side door won't open. I tried with the interior and exterior handles and both give no resistance. Is there some kind of linkage that might be broken or something?
    Thanks!
  2. #2 Re: Door Won't Open
    wow, that sucks, either way you look at it, the door has to be open so you can take the inside door panel off to see what is not working.
    not sure how you get the door open if both in and out side handles quit. other then sacrificing the door panel aka cutting it ripping it off. then reaching in to find the rods to push and pull on to open the door up.
  3. #3 Re: Door Won't Open
    GTX Level Member Travisgt2's Avatar
    Jan 2013
    leavenworth ks
    Sounds like that's what's got to happen. Time start looking for a door panel
    04 GT2: 180 t-stat, cold air intake, reptile tune, plog, hv3, gt1 cam, 90#springs, new push rods, new lifters, port polished heads, lim, uim and tb, 06 Impala brakes and steel brake lines. Cosmetic: black roof rails, under glow, Pontiac ground light, blue hud dic radio controls and cluster. To come custom hood.
  4. #4 Re: Door Won't Open
    Feb 2013
    37.295091, -121.930053
    oh boy i had this happen on a 74 corvette it took me 2 hrs to unlock it i would suggest that you roll down the window and get a hook to pull the latch up so it unlocks
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Door Won't Open
    Jan 2014
    AR
    If I were familiar with sedans maybe I could help more but I'm a coupe guy. I say remove the screws under the armrest, and the rear seat bottom for more clearance... then yep find a spot and pull the panel loose starting at the bottom. Chances of getting it open with the trim panel only partially removed might qualify as torture, so go ahead and try to get it out of the way.
  6. #6 Re: Door Won't Open
    if you do try this way i suggest taking the pass side back inside trim off and seeing how stuff works, then make a tool, aka wire hanger to hook that you need to hook on the pass side, then take what you learned to the driver side door.
  7. #7 Re: Door Won't Open
    One BadAzz GT Dawgg Mirraco's Avatar
    Aug 2012
    Brainerd, MN
    I would try my hardest to use a hanger before i ruined my door panel, but that may have to be what happens. I have always been lucky and one of the handles will open the door, and only have expeirence on the front doors. Have never taken my rear panels off, but I assume its similar to the front ones. I have had to put a new regulator and motor in the front passenger, and its just a simple metal piece that opens the door up.
    01 GP GT navy blue 70K miles and counting, dd. 17" 05 gtp wheels, 35% tint, 05 heated leather, smoked led tail lights, k+n filter, zzp catted downpipe, 2004 exhaust, roof rails, reptile tune 08 G6 GT coupe 95k miles, racekar. 2 alpine type x 12", two alpine pdx 600 amps, pioneer 8000nex head unit (GPS ), heated leather, autostart.
  8. #8 Re: Door Won't Open
    GT Level Member mguzzo's Avatar
    Buffalo NY
    its been a while since I had a sedan. do the rear doors have the child safety mechanism that prevents the door from opening from the inside? I wonder if that is making the outer mechanism not work too
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  9. #9 Re: Door Won't Open
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    At work we had this happen to a '08 Durango, we pried the top of the door panel off enough to get a hand in there and the boss got a wire and touched some stuff together to get it to work, in the process blowing the fuse for all the door latches, lol. But we got it open. I'll ask him tomorrow what exactly was up with it.
    EDIT: Sorry, forgot to respond. I guess the reason the door didn't work was because of some canine unit wiring that got cut wrong when the PD tried to take apart the car themselves.
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  10. #10 Re: Door Won't Open
    Jan 2014
    AR
    The trouble on sedans is that the rear door latches are crammed back in the corner underneath the stationary glass. If the exterior door handle rod clip broke or came loose while the door was child-locked, for example... you'll need good access to reach and manipulate the latch. Scotty's suggestion about taking the other rear door's trim panel off for reference is solid, thats a good idea to help minimize damage. One scratch on the exterior paint isn't worth one salvage sedan rear door trim panel.
  11. #11 Re: Door Won't Open
    Jul 2015
    Kalamazoo, Michigan
    Sweet! Thanks for all of the responses! I'll take a look at this within the next couple of days and reply back here with how it goes!
  12. #12 Re: Door Won't Open
    Sometimes you can hump the door while you try to open it, it takes the weight off the striker on the door and might allow it to release.
    I however just had the opposite issue, my door doesn't/didn't close, the latch no longer wants to grab the striker bolt and stay latched and thats dangerous.
  1. Key doen't want to open my door
    By hockeybawler in forum General Grand Prix Discussion
    Last Post: 05-14-2013, 10:15 PM
  2. HELP with the door open chime
    By asite57 in forum General Tech Discussion
    Last Post: 09-27-2012, 06:36 AM
  3. How To Open A Seized Door
    By Lakerman in forum General Tech Discussion
    Last Post: 01-26-2011, 09:26 AM
  4. Door won't open.
    By jjames137 in forum General Tech Discussion
    Last Post: 03-02-2010, 09:17 PM
  5. door open
    By echarleswhyte in forum Off Topic Discussion
    Last Post: 10-11-2009, 02:27 PM
