As the title describes, I'm having an issue with the lights dimming rhythmically. It is not limited to a particular set of lights, the problem affects all lighting (headlights, interior, dash & DIC, etc). Here's a list of things that I have performed/checked:
Battery is less than 3 months old, tested and performing excellent. CCA & voltage all well above minimum spec.
Terminal connections are free of corrosion and tight.
Alternator appears to be OEM (116k miles), voltage was 14.1 unloaded and 13.8 under load. Connections are also clean and tight
Now here's what I have added/upgraded on the car electrically:
Big 3 upgrade: 4 gauge power wire from alternator stud directly to positive battery terminal (150A fuse)
4 gauge ground wire from rear alternator bolt to frame ground by battery
4 gauge ground wire from battery negative to frame ground
Frame ground by battery was cleaned to bare metal
Ground underneath driver side headlight was cleaned to bare metal
I do have all upgraded interior speakers driven by an amplifier. The amplifier is a Pioneer GM-D8604 4 channel amp. 600W RMS rated power, hooked up with 4 ga power and ground. The gains are set very low to not overdrive the new speakers. All connections on amp are clean and tight. Ground is on one of the strut bolts, bare metal and tight.
Here's my speculation ...
I do not see, or know of a ground between the engine and firewall. However, I am aware of a ground that runs from somewhere on the engine block to subframe. I did not upgrade this ground, as I safely assumed that the ground wire from the alternator to frame ground would handle this task better (path of least resistance and whatnot) and I read that it is already a considerable size (4 gauge IIRC)
One of my neighbors is an electrician, and he said that it could be a connection shorting out somewhere in the vehicle. My other neighbor, who was a mechanic for a number of years, looked over my work and said he believes that the alternator is the most likely culprit. I cannot quote exactly what he said (I think it was rectifier) but it was one of the internal components he believes is failing and is causing a "pulsing" throughout the charging system. This pulsing did not show up on my DVOM, and I would imagine that it would have to be at least half a volt for the lights to dim like this (about 3 times a second).
I did notice that when I use one or both of the power windows, the dimming will get worse as the motors are operating, then when I release the switch all lights will not dim for a few seconds, then it resumes again.
I hope you guys have some good ideas for me! Thanks again for your time!
- Ryan
